this is my code program, does anyone know why I keep getting an error? the error message is like this:
C:\Users\Lenovo\OneDrive\Documents\Arduino\libraries\PulseSensorPlayground-master\src\PulseSensorPlayground.cpp: In member function 'int PulseSensorPlayground::getPulseAmplitude(int)':
C:\Users\Lenovo\OneDrive\Documents\Arduino\libraries\PulseSensorPlayground-master\src\PulseSensorPlayground.cpp:209:5: error: return-statement with no value, in function returning 'int' [-fpermissive]
209 | return; // out of range.
C:\Users\Lenovo\OneDrive\Documents\Arduino\libraries\PulseSensorPlayground-master\src\PulseSensorPlayground.cpp: In member function 'long unsigned int PulseSensorPlayground::getLastBeatTime(int)':
C:\Users\Lenovo\OneDrive\Documents\Arduino\libraries\PulseSensorPlayground-master\src\PulseSensorPlayground.cpp:216:5: error: return-statement with no value, in function returning 'long unsigned int' [-fpermissive]
216 | return; // out of range.
exit status 1
Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#define USE_ARDUINO_INTERRUPTS true
#include <PulseSensorPlayground.h>
#include <ArduinoJson.h>
const int PulseWire = 0;
const int LED13 = 13;
int Threshold = 550;
PulseSensorPlayground pulseSensor;
// Initialize Wifi connection to the router
char ssid[] = "***"; // diisi nama wifi
char password[] = "***"; // diisi password wifi
// Initialize Telegram BOT
#define BOTtoken "5168512905:AAFpH1ltbhE_gh6O1qjYJLdN1RnjiJTC8tU" // diisi Token Bot (Dapat dari Telegram Botfather)
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
//Checks for new messages every 1 second.
int botRequestDelay = 1000;
unsigned long lastTimeBotRan;
void handleNewMessages(int numNewMessages) {
Serial.println("handleNewMessages");
Serial.println(String(numNewMessages));
for (int i=0; i<numNewMessages; i++) {
String chat_id = String(bot.messages[i].chat_id);
String text = bot.messages[i].text;
String from_name = bot.messages[i].from_name;
if (from_name == "") from_name = "Guest";
//Cek Detak Jantung Pasien
if (text == "/detakjantung") {
int myBPM = pulseSensor.getBeatsPerMinute();
if (pulseSensor.sawStartOfBeat()) {
String detak = "Detak Jantung Saat Ini: ";
detak += int(myBPM);
detak +=" BPM";
Serial.println(myBPM);
bot.sendMessage(chat_id,detak, "");
//Cek Command untuk setiap aksi
if (text == "/start") {
String welcome = "Welcome " + from_name + ".\n";
welcome += "/detakjantung : Cek Detak Jantung Pasien\n";
welcome += "/volumeinfus : Cek Volume Infus\n";
welcome += "/kualitastidur : Cek Kualitas Tidur Pasien\n";
bot.sendMessage(chat_id, welcome, "Markdown");
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13);
pulseSensor.setThreshold(Threshold);
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !");
client.setInsecure();
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print("Connecting...");
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
Serial.println("♥ A HeartBeat Happened ! ");
Serial.print("BPM: ");
delay(20);
if (millis() > lastTimeBotRan + botRequestDelay) {
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while(numNewMessages) {
Serial.println("got response");
handleNewMessages(numNewMessages);
lastTimeBotRan = millis();
