Error: 'rfid' does not name a type
When I try to upload this code I get 2 errors:
240:3: error: 'rfid' does not name a type
rfid.halt();
and
241:1: error: expected declaration before '}' token
The code is below
//Include sections
#include <RFID.h>
#include <SPI.h>
#include <LiquidCrystal.h>
#include <Servo.h>
//Define Component to Arduino Pins
#define SS_PIN 10
#define RST_PIN 9
#define SERVO_PIN 5
#define Red_LED 6
#define Green_LED 7
#define Buzzer 8
//initialize the library with the numbers of the interface pins
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
Servo DoorLock;
RFID rfid(SS_PIN, RST_PIN );
//Unique ID of RFID Tag, which you want to give access.
int My_RFID_Tag[5] = {"03 41 0F AC"};
//variable to hold your Access_card
boolean My_Card = false;
  //set the pins as an input/output
  pinMode(Red_LED,OUTPUT);
  pinMode(Green_LED,OUTPUT);
  pinMode(Buzzer,OUTPUT);
  //Servo Connnected to pin Digital Pin 5
  DoorLock.attach(SERVO_PIN);
  //open the serial port at 9600 baudrate.
  //Initialise the LCD to 16x2 Character Format
  lcd.begin(16,2);
  //Initialise Servo and RFID
  SPI.begin();
  rfid.init();
  //First Assume detected card(Or tag) is My_Card,
  //Then later we will check is it My_Card or not!
  My_Card = true;
  DoorLock.write(0); //Servo at 0 Position, Door is Closed.
  lcd.clear();
  lcd.print("Robodia Technology");
  lcd.setCursor(0,1);
  lcd.print("gy Solutions!");
  //Check if any RFID Tags Detected or not?
  if( rfid.isCard() )
      //if RFID Tag is detected, check for the Unique ID,
      //and print it on the Serial Window
      if( rfid.readCardSerial() )
          lcd.clear();
          lcd.print("UNIQUE ID is:- ");
          lcd.setCursor(0,1); //Set LCD Cursor to Second Row, First Character
      //Unique id is 5 Digit Number.
          //Printing in HEX for better Understanding
          for( int i = 0; i < 5; i++ )
              Serial.print(rfid.serNum[i], HEX);
              Serial.print(" ");
              lcd.print(rfid.serNum[i],HEX);
              lcd.print(" ");
      //Compare this RFID Tag Unique ID with your My_RFID_Tag's Unique ID
          for(int i = 0; i < 5; i++)
              //if any one Unique ID Digit is not matching,
              //then make My_Card = false and come out from loop
              //No need to check all the digit!
              if( My_RFID_Tag[i] != rfid.serNum[i] )
                My_Card = false;
          //If RFID Tag is My_Card then give access to enter into room
          //else dont open the door.
          if(My_Card)
            Serial.println("\nWelcome To Your Room, Robodia!");
            lcd.clear();
            lcd.print("Welcome to Your");
            lcd.setCursor(0,1);
            lcd.print("Room, Robodia!");
            delay(2000);
            //Turn on the Green LED as an indication of permission is given
            //to access the room.
            digitalWrite(Green_LED,HIGH);
              int i = 0;
              i =  i + 1;
            //Now, Open the Door with the help of Servo Motor
            DoorLock.write(180);
            delay(200);
            lcd.clear();
            lcd.print("Door is Open");
            lcd.setCursor(0,1);
            lcd.print("Now!");
            delay(2000);
            lcd.clear();
            //Give 10 Sec delay to enter into room
            //After that door will again closed!
            for(int i = 10; i > 0; i--)
              lcd.print("Door will close");
              lcd.setCursor(0,1);
              lcd.print("in ");
              lcd.print(i);
              lcd.print(" Sec.HurryUp!");
              lcd.clear();
            //Now,Door is closed and Green LED is Turned-Off.
            DoorLock.write(0);
            digitalWrite(Green_LED,LOW);
            delay(200);
            lcd.clear();
            lcd.print("Door is Close");
            lcd.setCursor(0,1);
            lcd.print("Now!");
            delay(2000);
          // If RFID Tag is not My_Card then
          // Do not open the Door and
          //Turn-On Red LED and Buzzer as an indication of Warning:
          //Somebody else is trying to enter into your room.
            Serial.println("\nGet Out of Here !");
            lcd.clear();
            lcd.print("Card isNOT FOUND!");
            lcd.setCursor(0,1);
            lcd.print("Get Out of Here!");
            for(int i = 0; i < 7; i++)
              digitalWrite(Buzzer, HIGH);
              digitalWrite(Red_LED,HIGH);
              digitalWrite(Buzzer, LOW);
              digitalWrite(Red_LED,LOW);
  //Put RFID Reader into Halt, untill it not detects any RFID Tag.
  rfid.halt();
Match up your "curly" braces ( '{' and '}' ). You seem to have one or two "extra" ones.
that worked i removed the curly brace that was throwing the error and now the code compiles fine thanks
