Dear all,
I have problem when creating a program in arduino uno. I want to combine between reading a rotary encoder (omron model E6B2 CWZ3E 2000 omron model E6B2 CWZ3E 2000 p/r ) and reading a temperature sensor (DS18S20).
I tried using example in playground.arduino.cc to test separately between rotary encoder and DS18S20 and It successful. I used this code to test rotary encoder:
/* NOTES
1. This program without interupt, but OK
2. source: http://playground.arduino.cc/Main/RotaryEncoders
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
int val;
int encoder0PinA = 2;
int encoder0PinB = 3;
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
pinMode (encoder0PinA,INPUT);
pinMode (encoder0PinB,INPUT);
Serial.begin (9600);
Serial.println(" ");
Serial.println("Bismillaah... begin reading encoder");
Serial.println("diambil dari file _3__encoder.ino");
lcd.begin(16, 2);
lcd.setCursor(0, 0); lcd.print("Bismillah ...");
lcd.setCursor(0, 1); lcd.print("3_encoder.ino");
lcd.setCursor(0, 1); lcd.print("Encoder 2014");
lcd.setCursor(0, 0); lcd.print("--Read Encoder--");
n = digitalRead(encoder0PinA);
if ((encoder0PinALast == LOW) && (n == HIGH)) {
if (digitalRead(encoder0PinB) == LOW) {
encoder0Pos--;
encoder0Pos++;
Serial.print(encoder0Pos);
Serial.print("/");
lcd.setCursor(0, 1); lcd.print(" ");
lcd.setCursor(5, 1); lcd.print(encoder0Pos);
encoder0PinALast = n;
It works. The result from that program, if I turn the encoder, it show integer.
Then I used this code below to combine rotary encoder with temperature sensor.
/* NOTES
3. source: http://playground.arduino.cc/Learning/OneWire
#include <OneWire.h>
//Temperature chip i/o
int DS18S20_Pin = 8; //DS18S20 Signal pin on digital 2
OneWire ds(DS18S20_Pin); // on digital pin 2
byte SimbolDerajat[8] = {6,9,9,6,0,0,0};
//byte SimbolDerajat[8] = {0,10,31,31,14,4,0};
int val;
int n = LOW;
void setup(void) {
Serial.println("Bismillaah... begin reading encoder and DS18S20");
Serial.println("diambil dari file _4__encoder_DS.ino");
lcd.begin(16, 2);
lcd.createChar(0, SimbolDerajat);
lcd.setCursor(0, 1); lcd.print("4_encoder_DS.ino");
lcd.setCursor(0, 1); lcd.print("Encoder and Temp");
lcd.clear();
encoder0Pos--;
encoder0Pos++;
lcd.setCursor(0, 0); lcd.print("Putar: ");
lcd.print(encoder0Pos); lcd.print(" ");
Serial.print("Putaran: ");
Serial.print(encoder0Pos); Serial.print(". ");
// int putar = getEncoder();
float suhu = getTemp();
lcd.setCursor(0, 1); lcd.print("Suhu: ");
lcd.print(suhu,1); lcd.print(" ");
lcd.write((uint8_t)0); lcd.print("C");
Serial.print("Suhu: ");
Serial.print(suhu); Serial.println(" deg C");
// delay(100); //just here to slow down the output so it is easier to read
int getEncoder(){
encoder0Pos--;
encoder0Pos++;
return encoder0Pos;
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
The result, when I turn the rotary encoder, the LCD show integer, but not simultaneously;…
Could you help my problem?
Thank you for your attention…
regards
