Error showing a function
Hello again, please I have a question, I programmed an array basic operations calculator, the problem I have is trying to show the answer, it just shows an empty space. Please maybe you can tell me what I'm doing wrong:
//Decalration of variables
int menu();
void leer(char t, float *va);
void leer2(char t, float *va);
void mostrar(float *va);
void sum(float *va, float *vb, float *vc);
void res(float *va, float *vb, float *vc);
void pro(float *va, float *vb, float *vc);
void coc(float *va, float *vb, float *vc);
float v1[4];
float v2[4];
float v3[4];
Serial.println(" --------------------------");
Serial.println(" CALCULADORA CON VECTORES");
int i, active, minuta, tam;
active = 0;
do
minuta = menu();
switch (minuta)
  case 1:
      leer('A', v1);
      leer2('B', v2);
      sum(v1, v2, v3);
      mostrar(v3);
  case 2:
      leer('A', v1);
      leer2('B', v2);
      res(v1, v2, v3);
      mostrar(v3);
  case 3:
      leer('A', v1);
      leer2('B', v2);
      pro(v1, v2, v3);
      mostrar(v3);
  case 4:
      leer('A', v1);
      leer2('B', v2);
      coc(v1, v2, v3);
      mostrar(v3);
  case 5:
      active = 1;
} while (active == 0);
//Declaration of reading values function
int i, tam;
Serial.print("\nLONGITUD DEL VECTOR--> ");
do
tam = Serial.parseInt();
} while (Serial.available() == 0);
Serial.println(tam);
Serial.print("INSERTAR VALORES VECTOR ");
Serial.print(t);
Serial.println("--> ");
for (i = 0; i < tam; i += 1)
Serial.print("V");
Serial.print("[");
Serial.print(i);
Serial.print("] = ");
do
  va[i] = Serial.parseFloat();
Serial.println(va[i]);
//Second declaration of reading values function
int i, tam;
do
Serial.print(t);
Serial.print("V");
Serial.print("[");
Serial.print(i);
do
//Function to show values
int i, tam;
Serial.print("VECTOR RESULTANTE--> ");
Serial.print(" V: ");
Serial.print("[ ");
Serial.print(va[i]);
Serial.print(" | ");
Serial.println(" ]");
//Menu
int menu()
int opc;
Serial.println("MENU PRINCIPAL");
Serial.println("1. SUMA");
Serial.println("2. RESTA");
Serial.println("3. PRODUCTO");
Serial.println("4. COCIENTE");
Serial.println("5. SALIR");
Serial.print("INTRODUCIR OPCION--> ");
do
opc = Serial.parseInt( );
Serial.println(opc);
return opc;
//Function to add
int i, tam;
vc[i] = va[i] + vb[i];
//Function to subtract
int i, tam;
vc[i] = (va[i]) - (vb[i]);
//Function to multiply
int i, tam;
vc[i] = (va[i]) * (vb[i]);
//Function to divide
int i, tam;
vc[i] = (va[i]) / (vb[i]);
maybe these lines should read
while (Serial.available() != 0)
Sorry, it didn't work.
OK. but i'm quite sure, you do not want to parse the Serial-Input while there is no data available (Serial.available()==0)
in the function mostrar you define a variable named tam and use ist in a for-loop, but never assign any value to ist.
ist this ok?
I think you should delete all lines reading
int i, tam;
and put ONE copy of this line to the begin, where you define your variables.
have a look here
[scope - Arduino Reference]
Thanks a lot my friend, now it works properly:+1:
