error: sim900 doesn't answer. check power and serial pins in gsm.cpp status=idle
hi..im really need help here.im working with sim900 quad-band gsm/gprs shield and arduino uno R3
when i uploading the program, the serial monitor always show this..
GSM Shield testing. DB:NO RESP DB:NO RESP DB:NO RESP Trying to force the baud-rate to 9600
1200 2400 4800 9600 19200 38400 57600 115200 ERROR: SIM900 doesn't answer. Check power and serial pins in GSM.cpp
status=IDLE
please help me..
Also check the link in my signature, it may help depending on what shield you are using.
still no result I don t know where is the problem my code is correct 100%
this is the code
#include <SoftwareSerial.h>
char inchar;
SoftwareSerial SIM900(7, 8);
int led1 = 10;
int led2 = 11;
int led3 = 12;
int led4 = 13;
Serial.begin(19200);
// set up the digital pins to control
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
// wake up the GSM shield
SIM900power();
SIM900.begin(19200);
delay(20000);
SIM900.print(“AT+CMGF=1\r”);
delay(100);
SIM900.print(“AT+CNMI=2,2,0,0,0\r”);
delay(100);
Serial.println(“Ready…”);
void SIM900power()
digitalWrite(9, HIGH);
digitalWrite(9, LOW);
delay(7000);
if(SIM900.available() >0)
inchar=SIM900.read();
if (inchar==’#’)
delay(10);
if (inchar==‘a’)
delay(10);
if (inchar==‘0’)
else if (inchar==‘1’)
digitalWrite(led1, HIGH);
delay(10);
if (inchar==‘b’)
if (inchar==‘0’)
digitalWrite(led2, HIGH);
delay(10);
if (inchar==‘c’)
if (inchar==‘0’)
digitalWrite(led3, HIGH);
delay(10);
if (inchar==‘d’)
delay(10);
if (inchar==‘0’)
digitalWrite(led4, HIGH);
delay(10);
SIM900.println(“AT+CMGD=1,4”);
the line 3 is SoftwareSerial SIM900(7, 8 );
Cross-post (sock puppet zohairanniha/rivolutionario) Thread locked Please post answers here
