Hello
when i try to send GPS coordinates via SMS message and send data via gprs to server same time i have this error :
ERROR: SIM900 doesn’t answer. Check power and serial pins in GSM.cpp
this is my code, any one have a solution ?
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "inetGSM.h"
#include "sms.h"
#include "gps.h"
#include <Wire.h>
#include <ADXL345.h>
#define ScaleFor2G 0.0039
#define Threshold 0.5
ADXL345 adxl; //
InetGSM inet;
SMSGSM sms;
GPSGSM gps;
char msg[50];
int numdata;
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
char msg1[5];
char msg2[5];
char Mobile[]="0595285486";
char stat;
char inSerial[50];
int i=0;
boolean started=false;
int D5 = 5; // digital pin 5
int Led=13;
int Shock=8;
int val;
char smsbuffer2[150];
char id[]="12";
char httpbuffer[160];
adxl.powerOn();
pinMode(D5,INPUT);
pinMode(Led,OUTPUT);
pinMode(Shock,INPUT);//
{ int x,y,z;
adxl.readAccel(&x, &y, &z); //read the accelerometer values and store them in variables x,y,z
int sensorReading = digitalRead(D5);
val=digitalRead(Shock);
//activity
if(((x>500||y>500||z>500)&&val==0)||sensorReading==0){
Serial.println("activity");
digitalWrite(Led,HIGH);
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)) {
Serial.println("\nstatus=READY");
started=true;
gsm.forceON();
} else Serial.println("\nstatus=IDLE");
if(started) {
//GPS attach
if (gps.attachGPS())
Serial.println("status=GPSREADY");
else Serial.println("status=ERROR");
delay(20000); //Time for fixing
stat=gps.getStat();
if(stat==1)
Serial.println("NOT FIXED");
else if(stat==0)
Serial.println("GPS OFF");
else if(stat==2)
Serial.println("2D FIXED");
else if(stat==3)
Serial.println("3D FIXED");
delay(5000);
//Get data from GPS
gps.getPar(lon,lat,alt,time,vel);
Serial.println(lon);
Serial.println(lat);
Serial.println(alt);
Serial.println(time);
Serial.println(vel);
convert2Degrees(lat);
convert2Degrees(lon);
started=true;
if(started) {
//GPRS attach, put in order APN, username and password.
//If no needed auth let them blank.
if (inet.attachGPRS("internet", "", ""))
Serial.println("status=ATTACHED");
//Read IP address.
gsm.SimpleWriteln("AT+CIFSR");
delay(5000);
//Read until serial buffer is empty.
gsm.WhileSimpleRead();
//TCP Client GET, send a GET request to the server and
//save the reply.
httpbuffer[0]='\0';
strcat(httpbuffer,"/GetData.aspx?lat=");
strcat(httpbuffer,lat);
strcat(httpbuffer,"&&lon=");
strcat(httpbuffer,lon);
strcat(httpbuffer,"&&id");
strcat(httpbuffer,id);
Serial.println(httpbuffer);
numdata=inet.httpPOST("qou.azurewebsites.net", 80,httpbuffer, msg, msg,12);
//Print the results.
Serial.println("\nNumber of data received:");
Serial.println(numdata);
Serial.println("\nData received:");
Serial.println(msg);
if(started){
smsbuffer2[0]='\0';
strcat(smsbuffer2,"Vehicle Accident Occurs to Vehicle which Have ");
strcat(smsbuffer2,"ID number");
strcat(smsbuffer2,id);
strcat(smsbuffer2,"in Location :");
strcat(smsbuffer2,lat);
strcat(smsbuffer2,lon);
strcat(smsbuffer2,"Owner Name:Ayman Abd Albasit Sadq Daqah");
strcat(smsbuffer2,"Mobile :");
strcat(smsbuffer2,Mobile);
if (sms.SendSMS(Mobile, smsbuffer2))
Serial.println("\nSMS sent OK");
digitalWrite(Led,LOW);
int8_t convert2Degrees(char* input){
float deg;
float minutes;
boolean neg = false;
//auxiliar variable
char aux[10];
if (input[0] == '-')
neg = true;
strcpy(aux, strtok(input+1, "."));
strcpy(aux, strtok(input, "."));
// convert string to integer and add it to final float variable
deg = atof(aux);
strcpy(aux, strtok(NULL, '\0'));
minutes=atof(aux);
minutes/=1000000;
if (deg < 100)
minutes += deg;
deg = 0;
minutes += int(deg) % 100;
deg = int(deg) / 100;
// add minutes to degrees
deg=deg+minutes/60;
if (neg == true)
deg*=-1.0;
neg = false;
if( deg < 0 ){
neg = true;
deg*=-1;
float numeroFloat=deg;
int parteEntera[10];
int cifra;
long numero=(long)numeroFloat;
int size=0;
while(1){
size=size+1;
cifra=numero%10;
numero=numero/10;
parteEntera[size-1]=cifra;
if (numero==0){
int indice=0;
if( neg ){
indice++;
input[0]='-';
for (int i=size-1; i >= 0; i--)
input[indice]=parteEntera[i]+'0';
indice++;
input[indice]='.';
indice++;
numeroFloat=(numeroFloat-(int)numeroFloat);
for (int i=1; i<=6 ; i++)
numeroFloat=numeroFloat*10;
cifra= (long)numeroFloat;
numeroFloat=numeroFloat-cifra;
input[indice]=char(cifra)+48;
indice++;
input[indice]='\0';
