Error : sketch_jan05a.ino: In function 'void loop()
Bonsoir ,
Je viens de terminer mon programme sauf que ça m'affiche un grand message :
C:\Users\lokyw\OneDrive\Desktop\Programmation\Programmes Arduino\sketch_jan05a\sketch_jan05a.ino: In function 'void loop()':
C:\Users\lokyw\OneDrive\Desktop\Programmation\Programmes Arduino\sketch_jan05a\sketch_jan05a.ino:74:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
myTags = "";
    Donc je ne comprend pas pourquoi ça me dit ca .
    Mon programme complet :
    * *#include <SPI.h> #include <MFRC522.h> #include <LiquidCrystal.h> #include <Servo.h> #define RST_PIN  9 #define SS_PIN    10 byte readCard[4]; char* myTags[100] = {}; int tagsCount = 0; String tagID = ""; boolean successRead = false; boolean correctTag = false; int proximitySensor; boolean doorOpened = false; // Create instances MFRC522 mfrc522(SS_PIN, RST_PIN); LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Parameters: (rs, enable, d4, d5, d6, d7) Servo myServo; // Servo motor void setup() {   // Initiating   SPI.begin();        // SPI bus   mfrc522.PCD_Init(); //  MFRC522   lcd.begin(16, 2);  // LCD screen   myServo.attach(8);  // Servo motor   myServo.write(10); // Initial lock position of the servo motor   // Prints the initial message   lcd.print("-Pas De Carte Principale!-");   lcd.setCursor(0, 1);   lcd.print("    SCANNE MAINTENANT");   // Waits until a master card is scanned   while (!successRead) {     successRead = getID();     if ( successRead == true) {       myTags[tagsCount] = strdup(tagID.c_str()); // Sets the master tag into position 0 in the array       lcd.clear();       lcd.setCursor(0, 0);       lcd.print("Configurer La Carte Principale!");       tagsCount++;     }   }   successRead = false;   printNormalModeMessage(); } void loop() {   int proximitySensor = analogRead(A0);   // If door is closed...   if (proximitySensor > 200) {     if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue       return;     }     if ( ! mfrc522.PICC_ReadCardSerial()) {  //Since a PICC placed get Serial and continue       return;     }     tagID = "";     // The MIFARE PICCs that we use have 4 byte UID     for ( uint8_t i = 0; i < 4; i++) {  //       readCard[i] = mfrc522.uid.uidByte[i];       tagID.concat(String(mfrc522.uid.uidByte[i], HEX)); // Adds the 4 bytes in a single String variable     }     tagID.toUpperCase();     mfrc522.PICC_HaltA(); // Stop reading     correctTag = false;     // Checks whether the scanned tag is the master tag     if (tagID == myTags[0]) {       lcd.clear();       lcd.print("Mode programme:");       lcd.setCursor(0, 1);       lcd.print("Ajouter / supprimer une Carte");       while (!successRead) {         successRead = getID();         if ( successRead == true) {           for (int i = 0; i < 100; i++) {             if (tagID == myTags[i]) {               myTags[i] = "";               lcd.clear();               lcd.setCursor(0, 0);               lcd.print("  Carte Enlevée!");               printNormalModeMessage();               return;             }           }           myTags[tagsCount] = strdup(tagID.c_str());           lcd.clear();           lcd.setCursor(0, 0);           lcd.print("  Carte Ajoutée!");           printNormalModeMessage();           tagsCount++;           return;         }       }     }     successRead = false;     // Checks whether the scanned tag is authorized     for (int i = 0; i < 100; i++) {       if (tagID == myTags[i]) {         lcd.clear();         lcd.setCursor(0, 0);         lcd.print(" Accès Autorisé!");         myServo.write(170); // Unlocks the door         printNormalModeMessage();         correctTag = true;       }     }     if (correctTag == false) {       lcd.clear();       lcd.setCursor(0, 0);       lcd.print(" Accès Refusé!");       printNormalModeMessage();     }   }   // If door is open...   else {     lcd.clear();     lcd.setCursor(0, 0);     lcd.print(" Porte Ouverte!");     while (!doorOpened) {       proximitySensor = analogRead(A0);       if (proximitySensor > 200) {         doorOpened = true;       }     }     doorOpened = false;     delay(500);     myServo.write(10); // Locks the door     printNormalModeMessage();   } } uint8_t getID() {   // Getting ready for Reading PICCs   if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue     return 0;   }   if ( ! mfrc522.PICC_ReadCardSerial()) {  //Since a PICC placed get Serial and continue     return 0;   }   tagID = "";   for ( uint8_t i = 0; i < 4; i++) {  // The MIFARE PICCs that we use have 4 byte UID     readCard[i] = mfrc522.uid.uidByte[i];     tagID.concat(String(mfrc522.uid.uidByte[i], HEX)); // Adds the 4 bytes in a single String variable   }   tagID.toUpperCase();   mfrc522.PICC_HaltA(); // Stop reading   return 1; } void printNormalModeMessage() {   delay(1500);   lcd.clear();   lcd.print("-Contrôle D'accès-");   lcd.setCursor(0, 1);   lcd.print(" Scannez Votre Carte!"); }* *
myTags[100] est mal déclaré comme te le dit le compilo..
D'accord et pour le void loop () comment je pourrai faire ?
Loop va bien le compilateur t'indique où il a identifié l'erreur.
