Hello!
We are working on adding Arduino 3rd party support to a RISC-V based board SHAKTI (Parashu). While adding the String Library ( WString.h) and testing. Whenever a String object is declared inside setup() or loop() function it works fine, but when I declare a String object outside that in the editor I end up with either getting a string printed (null) or a error as per below.
Case when the code runs :
//CASE 1
String str1 = "abcde1234";
Serial.println(str1);
Output:
abcde1234
When I declare the String object outside the function
//CASE 2
Output:
(null)
Incase I just declare the String object and try to set value or string after
//CASE 3
String str1;
str1 = "abcde1234";
I encounter a error saying "str1 does not name a type"
/home/sambhav/.arduino15/packages/shakti/tools/riscv32-unknown-elf-gcc/1.0/bin/riscv32-unknown-elf-g++ -c -march=rv32imac -w -fpeel-loops -mcmodel=medany -ffreestanding -nostdinc++ -fno-builtin-printf -fdata-sections -fpermissive -Wall -fno-rtti -fno-exceptions -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/system/include -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/system -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino/shakti-sdk/bsp/include -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino/shakti-sdk/bsp/drivers -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino/shakti-sdk/bsp/third_party/parashu -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino/shakti-sdk/bsp/libs -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino/shakti-sdk/bsp/third_party/parashu -g -include sys/cdefs.h -g -DARDUINO=10812 -DF_CPU=-DSHAKTI_ECLS -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/cores/arduino -I/home/sambhav/.arduino15/packages/shakti/hardware/riscv/1.0.0/variants/parashu /tmp/arduino_build_651804/sketch/test_string1.ino.cpp -o /tmp/arduino_build_651804/sketch/test_string1.ino.cpp.o
test_string1:2:1: error: 'str1' does not name a type
str1 = "abcde1234";
exit status 1
I am attaching the respective code as well below to the gitlab repository
WString.cpp
WString.h
It would be quite helpful to understand what the issue might be or normally how to tackle this issue. The compiler used here if riscv32-unkown-elf-g++
P.S:
The link to the arduino 3rd party repository is here if anyone is interested to try it out in their IDE as the installation steps are provided in the README
