i'm working in a project with GPS to limit the speed of the vehicle for my college project expo...
i found the project from this site http://nootropicdesign.com/projectlab/2010/04/05/speed-trap
I'm having problem with the code they provided,the problem is it is encountering a error: "taking address of temporary [-fpermissive]" while compiling with arduino IDE 1.6.5.
Please look at the project and help me to solve the error and also please help me to understand how to create a polygon in a map and check whether the latitude and longitude are present within that polygon..
and if you can provide any alternative code for that project it will be more helpful to me to complete my project with in time..
The code is as follows:
#include <NewSoftSerial.h>
#include <TinyGPS.h>
#define NUM_OFF 2
#define DELAY 50
#define TEST_BUTTON 9
#define DEFAULT_SPEED_LIMIT 55
#define NSPEEDZONES 6
boolean debugMode = true;
boolean speeding = false;
int blue[4];
int red[4];
int headlight1;
int headlight2;
class Vertex {
public:
Vertex(float llat, float llng) {
lat = llat;
lng = llng;
float lat;
float lng;
class SpeedZone {
public:
SpeedZone(int s) {
speedLimit = s;
void setVertices(int n, Vertex *v) {
nVertices = n;
vertices = v;
int nVertices;
Vertex *vertices;
int speedLimit;
SpeedZone *speedZones[NSPEEDZONES];
TinyGPS gps;
NewSoftSerial nss(2, 3);
boolean buttonPressed = false;
setupSpeedZones();
blue[0] = 12;
blue[1] = 13;
blue[2] = 14;
blue[3] = 15;
red[0] = 16;
red[1] = 17;
red[2] = 18;
red[3] = 19;
headlight1 = 10;
headlight2 = 11;
for(int i=0;i<4;i++) {
pinMode(blue[i], OUTPUT);
pinMode(red[i], OUTPUT);
pinMode(headlight1, OUTPUT);
pinMode(headlight2, OUTPUT);
pinMode(TEST_BUTTON, INPUT);
digitalWrite(TEST_BUTTON, HIGH);
randomSeed(analogRead(0));
// Allow EM-406a to power up
delay(3000);
// Establish serial connection to EM-406a
nss.begin(4800);
void setupSpeedZones() {
// Rockford Road
speedZones[0] = &SpeedZone(45);
speedZones[0]->setVertices(6, (Vertex[6]){
Vertex(45.027162772967756, -93.48137855529785),
Vertex(45.02946790848425, -93.4742546081543),
Vertex(45.02955889877115, -93.46193790435791),
Vertex(45.02861865883124, -93.46172332763672),
Vertex(45.02861865883124, -93.47412586212158),
Vertex(45.02649547957147, -93.48133563995361)});
// Schmidt Lake Rd
speedZones[1] = &SpeedZone(45);
speedZones[1]->setVertices(10, (Vertex[10]){
Vertex(45.044176126280206, -93.48219394683838),
Vertex(45.04390322470628, -93.47322463989258),
Vertex(45.043387740403595, -93.46974849700928),
Vertex(45.0440548368525, -93.46498489379883),
Vertex(45.0440548368525, -93.46185207366943),
Vertex(45.04332709488612, -93.46185207366943),
Vertex(45.0433574176529, -93.46580028533936),
Vertex(45.04272063617576, -93.46983432769775),
Vertex(45.043266449304376, -93.47434043884277),
Vertex(45.04332709488612, -93.48215103149414)});
// Vicksburg Lane
speedZones[2] = &SpeedZone(50);
speedZones[2]->setVertices(4, (Vertex[4]){
Vertex(45.042993543391, -93.48219394683838),
Vertex(45.04320580365836, -93.4812068939209),
Vertex(45.02722343561804, -93.48116397857666),
Vertex(45.02725376691909, -93.4823226928711)});
// I-494
speedZones[3] = &SpeedZone(65);
speedZones[3]->setVertices(8, (Vertex[8]){
Vertex(45.04453999302037, -93.45356941223145),
Vertex(45.03950629768142, -93.45369815826416),
Vertex(45.029255597252295, -93.45378398895264),
Vertex(45.02594950646131, -93.45386981964111),
Vertex(45.02616182995624, -93.4522819519043),
Vertex(45.028921963725224, -93.45168113708496),
Vertex(45.0390514238751, -93.4520673751831),
Vertex(45.044267093182235, -93.45150947570801)});
// Fernbrook Lane
speedZones[4] = &SpeedZone(40);
speedZones[4]->setVertices(4, (Vertex[4]){
Vertex(45.04317548081123, -93.4621524810791),
Vertex(45.04332709488612, -93.46099376678467),
Vertex(45.029680218928654, -93.46065044403076),
Vertex(45.02961955888205, -93.46189498901367)});
// Bounding rectangle for residential areas
// This should be defined last in the list because it's the "catch all" speed zone.
speedZones[5] = &SpeedZone(25);
speedZones[5]->setVertices(4, (Vertex[4]){
Vertex(45.045783186920296, -93.48395347595215),
Vertex(45.0456315793546, -93.44983577728271),
Vertex(45.02585851043667, -93.45009326934814),
Vertex(45.02594950646131, -93.48326683044434)});
if (debugMode) {
printSpeedZones();
* This is the point-in-polygon algorithm adapted from
* http://www.ecse.rpi.edu/Homepages/wrf/Research/Short_Notes/pnpoly.html
boolean inSpeedZone(int speedZone, float lat, float lng) {
SpeedZone *s = speedZones[speedZone];
int i, j;
boolean inside = false;
for (i = 0, j = s->nVertices-1; i < s->nVertices; j = i++) {
if ( ((s->vertices[i].lat > lat) != (s->vertices[j].lat > lat)) &&
(lng < (s->vertices[j].lng - s->vertices[i].lng) * (lat - s->vertices[i].lat) / (s->vertices[j].lat - s->vertices[i].lat) + s->vertices[i].lng) )
inside = !inside;
return inside;
boolean inSpeedZone(int speedZone) {
float lat, lng;
unsigned long fix_age;
// retrieves +/- lat/long in 100,000ths of a degree
gps.f_get_position(&lat, &lng, &fix_age);
return inSpeedZone(speedZone, lat, lng);
if (readGPS()) {
if (debugMode) {
debug();
speeding = isSpeeding();
if (digitalRead(TEST_BUTTON) == LOW) {
buttonPressed = true;
if ((speeding || buttonPressed) && (!(speeding && buttonPressed))) {
policeLights();
allOff();
bool readGPS() {
while (nss.available()) {
if (gps.encode(nss.read())) {
return true;
return false;
int getSpeedLimit() {
boolean isInSpeedZone;
for(int i=0;i<NSPEEDZONES;i++) {
isInSpeedZone = inSpeedZone(i);
if (isInSpeedZone) {
return speedZones[i]->speedLimit;
return DEFAULT_SPEED_LIMIT;
boolean isSpeeding() {
int speed = (int)(gps.f_speed_mph() + 0.5);
int speedLimit = getSpeedLimit();
if (speed > speedLimit) {
return true;
return false;
boolean policeLights() {
// The white LEDs are so bright we actually turn them down quite a bit.
// 0 is full brightness and 255 is off (because the cathode is connected to the PWM pin)
analogWrite(headlight2, 200);
analogWrite(headlight1, 200);
allOn();
// Turn off some of the red and blue lights to give them a flashing effect.
for(int i=0;i<NUM_OFF;i++) {
digitalWrite(blue[random(4)], HIGH);
digitalWrite(red[random(4)], HIGH);
delay(DELAY);
void allOn() {
digitalWrite(blue[i], LOW);
digitalWrite(red[i], LOW);
void allOff() {
digitalWrite(blue[i], HIGH);
digitalWrite(red[i], HIGH);
digitalWrite(headlight1, HIGH);
digitalWrite(headlight2, HIGH);
void printSpeedZones() {
SpeedZone *s = speedZones[i];
Serial.println(s->speedLimit);
for(int v=0;v<s->nVertices;v++) {
Serial.print("(");
Serial.print(s->vertices[v].lat);
Serial.print(", ");
Serial.print(s->vertices[v].lng);
Serial.println(")");
void debug() {
long lat, lon;
unsigned long fix_age, time, date, speed, course;
// retrieves +/- lat/long in 100000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
Serial.println(getSpeedLimit());
Serial.print("lat: ");
Serial.print(lat);
Serial.print(" lng: ");
Serial.print(lon);
Serial.print(" speed: ");
Serial.println(gps.f_speed_mph());
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags fixed.
