error "teleduino was not declared in this scope"???? (SOLUCIONADO)
me da este error al cargar este codigo , tiene solucion o no puedo usarlo, gracias
TeleduinoEthernetClientProxy.ino - TeleduinoEthernetClientProxy example
Version 328-0.6.7
Nathan Kennedy 2012
http://www.teleduino.org
This sketch is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
#include <Teleduino328.h>
#include <SPI.h>
#include <Ethernet.h>
// User configurable variables
byte useDhcp = true;
byte useDns = true;
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress deviceIp(192, 168, 1, 100); // Only if useDhcp is false
IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false
IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false
char serverName = “us01.proxy.teleduino.org”; // Only if useDns is true
unsigned int serverPort = 5353; // Can be set to either 53 or 5353
byte statusLedPin = 8;
// User configurable key, this is used to authenticate with the proxy server
// This is checked against the EEPROM on boot and written if necessary
// The proxy server retreives the key from the EEPROM
byte key = { };
// Other required variables
byte data[257];
byte dataLength;
byte hexStage;
unsigned long lastInstruction = 0;
unsigned long lastRefresh = 0;
byte stage = 0;
// Declare client object
EthernetClient Client;
// Load presets
Teleduino.loadPresets();
// Set status LED pin
Teleduino.setStatusLedPin(statusLedPin);
Teleduino.setStatusLed(1); // Initialisation
// Check the EEPROM header and check to see if the key is correct
// This is to ensure the key is not cleared from the EEPROM
if(EEPROM.read(0) != ‘#’)
EEPROM.write(0, ‘#’);
if(EEPROM.read(1) != 0)
EEPROM.write(1, 0);
if(EEPROM.read(2) != ‘#’)
EEPROM.write(2, ‘#’);
if(EEPROM.read(160) != ‘#’)
EEPROM.write(160, ‘#’);
for(byte i = 0; i < 16; i++)
if(EEPROM.read(161 + i) != key*)*
    _ EEPROM.write(161 + i, key*);_
    _
    }_
    _
    }_
    _
    if(EEPROM.read(177) != ‘#’)_
    _
    {_
    _
    EEPROM.write(177, ‘#’);_
    _
    }_
    _
    // Start network and attempt to connect to proxy server*_
    * Teleduino.setStatusLed(2); // Network configuration*
    * if(useDhcp)*
    * if(!Ethernet.begin(mac))*
    * Teleduino.setStatusLed(2, false, 10000);*
    * Teleduino.reset();*
    * else*
    * Ethernet.begin(mac, deviceIp, dnsIp, gatewayIp, subnet);*
    * delay(1000);*
    * Teleduino.setStatusLed(3); // Connect to server*
    * if((useDns && !Client.connect(serverName, serverPort)) || (!useDns && !Client.connect(serverIp, serverPort)))*
    * Teleduino.setStatusLed(3, false, 10000);*
    * lastInstruction = millis();*
    * if(Client.connected())*
    * // What we need to do depends on which ‘stage’ we are at*
    * switch(stage)*
    * case 0: // Wait for start byte*
    * if(Client.available())*
    * char c = Client.read();*
    * if(c == ‘?’)*
    * stage++;*
    * break;*
    * case 1: // Reset variables*
    * dataLength = 0;*
    * hexStage = 0;*
    * stage++;*
    * break;*
    * case 2: // Instruction byte*
    * if(c == ‘?’)*
    * stage = 1;*
    * break;*
    * else if(c == ‘\r’ || c == ‘\n’ || c == ‘.’)*
    * stage = 0;*
    * break;*
    * if(!hexStage)*
    _ data[0] = Teleduino.hexDecode(c) * 16;
    * else*
    * data[0] += Teleduino.hexDecode(c);*
    * hexStage = !hexStage;*
    * if(!hexStage)*
    * stage++;*
    * break;*
    * case 3: // Data length byte*
    * if(c == ‘?’)*
    * stage = 1;*
    * break;*
    * stage = 0;*
    * break;*
    * if(!hexStage)*
    data[1] = Teleduino.hexDecode(c) * 16;
    * else*
    * data[1] += Teleduino.hexDecode(c);*
    * if(!hexStage)*
    * stage++;*
    * break;*
    * case 4: // Data*
    * if(c == ‘?’)*
    * stage = 1;*
    * break;*
    * if(dataLength == data[1])*
    * stage++;*
    * break;*
    * else*
    * stage = 0;*
    * break;*
    * if(!hexStage)*
    data[2 + dataLength] = Teleduino.hexDecode(c) * 16;
    * else*
    * data[2 + dataLength] += Teleduino.hexDecode(c);*
    * if(!hexStage)*
    * dataLength++;*
    * break;*
    * case 5: // Execute instruction and return result*
    * Teleduino.instruction(data);*
    * Client.write(’!’);*
    * for(int i = 0; i < data[1] + 2; i++)*
    Client.write(Teleduino.hexEncode(data / 16));
    Client.write(Teleduino.hexEncode(data % 16));
    Client.write(’\n’);
    stage = 0;
    else*
    Teleduino.setStatusLed(10);
    Teleduino.reset();
    // Has the instruction timeout been reached?
    if(millis() - lastInstruction > 30000)
    Client.flush();
    Client.stop();
    Teleduino.setStatusLed(9);
    Teleduino.reset();
    // Process refreshes every 50ms*
    * if(millis() - lastRefresh >= 50)
    Teleduino.pinTimers();
    Teleduino.shiftRegisterTimers();
    Teleduino.shiftRegisters();
    lastRefresh = millis();
    // Check to see if reset has been requested*
    * Teleduino.checkReset();
    }ar el codigo , tiene solucion? o no puedo usar este codigo*_
Pues a mi me compila bien :expressionless:
Bájate la librería Teleduino328, que a mi me huele que te falta :wink:
Eres un crack tio muchas gracias y disculpa mi torpeza :~
