I now have some error linked to a class i tried to make.
I will post eveything i got since i can't untangle my files.
In file included from C:\Users\antoi\Documents\Arduino\Sprite_loading_3\myFunctions.cpp:3:0:
C:\Users\antoi\Documents\Arduino\Sprite_loading_3\myFunctions.h:45:1: error: 'Box1' does not name a type
Box1.BoxNum = 1;
C:\Users\antoi\Documents\Arduino\Sprite_loading_3\myFunctions.h:46:1: error: 'Box2' does not name a type
Box2.BoxNum = 2;
C:\Users\antoi\Documents\Arduino\Sprite_loading_3\myFunctions.h:47:1: error: 'Box3' does not name a type
Box3.BoxNum = 3;
C:\Users\antoi\Documents\Arduino\Sprite_loading_3\myFunctions.h:48:1: error: 'Box4' does not name a type
Box4.BoxNum = 4;
In file included from C:\Users\antoi\Documents\Arduino\Sprite_loading_3\Sprite_loading_3.ino:8:0:
Box1.BoxNum = 1;
Box2.BoxNum = 2;
Box3.BoxNum = 3;
Box4.BoxNum = 4;
Compilation error: exit status 1
.ino :
#include <stdlib.h>
#include <TFT_eSPI.h>
//extern TFT_eSPI tft = TFT_eSPI(320,240);
#include "images.h"
#include "myFunctions.h"
TFT_eSprite spr2 = TFT_eSprite(&tft);
TFT_eSprite spr3 = TFT_eSprite(&tft);
int center = ( 5 + 16 );
uint16_t tab_color[] = {
TFT_BLACK, // 0 ^
TFT_BROWN, // 1 |
TFT_RED, // 2 |
TFT_ORANGE, // 3 |
TFT_YELLOW, // 4 Colours 0-9 follow the resistor colour code!
TFT_GREEN, // 5 |
TFT_BLUE, // 6 |
TFT_PURPLE, // 7 |
TFT_DARKGREY, // 8 |
TFT_WHITE, // 9 v
TFT_CYAN, // 10 Blue+green mix
TFT_MAGENTA, // 11 Blue+red mix
TFT_MAROON, // 12 Darker red colour
TFT_DARKGREEN,// 13 Darker green colour
TFT_NAVY, // 14 Darker blue colour
TFT_PINK // 15
b_init();
tft.init();
tft.setRotation(1);
tft.fillScreen(TFT_CYAN);
spr3.setColorDepth(16);
spr3.createSprite(32,32);
spr3.setSwapBytes(true);
tft.drawRoundRect(4, 4, 66, 66, 11, 0);
tft.drawRoundRect(5, 5, 64, 64, 10, 0);
tft.drawRoundRect(4, 99, 34, 34, 6, 0);
tft.drawRoundRect(5, 100, 32, 32, 5, 0);
tft.drawRoundRect(44, 99, 34, 34, 6, 0);
tft.drawRoundRect(45, 100, 32, 32, 5, 0);
tft.drawRoundRect(84, 99, 34, 34, 6, 0);
tft.drawRoundRect(85, 100, 32, 32, 5, 0);
tft.drawRoundRect(124, 99, 34, 34, 6, 0);
tft.drawRoundRect(125, 100, 32, 32, 5, 0);
tft.drawRoundRect(6, 101, 30, 30, 4, TFT_RED);
tft.drawRoundRect(6, 100, 30, 30, 4, TFT_RED);
tft.drawRoundRect(7, 102, 28, 28, 3, TFT_PINK);
tft.setTextColor(TFT_RED);
tft.setTextSize(2);
tft.setCursor(75,6);
tft.print("Name: ""Egg");
tft.setCursor(75,30);
tft.print("Evolution: ""Egg");
tft.setCursor(75,54);
tft.print("Status: ""Uncoocked");
tft.setCursor(5,75);
tft.print("Action :");
//Act.UpdateMessage (Box1.BoxNum);
for (int i = 0; i < 8; i++)
tft.fillRect((0+(i*32)),176,32,32,tab_color[i]);
tft.fillRect((0+((i)*32)),208,32,32,tab_color[i+7]);
void loop(void) {
button_1.loop();
button_2.loop();
button_3.loop();
button_4.loop();
spr3.fillSprite(TFT_CYAN);
spr3.pushSprite(center,32, TFT_MAGENTA);
spr3.pushImage(0, 0, 128, 32, (uint16_t *)egg_1);
spr3.pushImage(-32, 0, 128, 32, (uint16_t *)egg_1);
spr3.pushImage(-64, 0, 128, 32, (uint16_t *)egg_1);
spr3.pushImage(-96, 0, 128, 32, (uint16_t *)egg_1);
images.h (not important )
extern const uint16_t stars[98304] PROGMEM ;
extern const uint16_t stars2[4096] PROGMEM ;
extern const uint16_t stars3[4096] PROGMEM ;
extern const uint16_t egg_1[4096] PROGMEM ;
images.cpp is ust a few images
Button2.h (from a lib )
Button2.h - Arduino Library to simplify working with buttons.
Created by Lennart Hennigs.
#pragma once
#ifndef Button2_h
#define Button2_h
#if defined(ARDUINO_ARCH_ESP32) || defined(ESP8266)
#include <functional>
#endif
#include "Arduino.h"
#define DEBOUNCE_MS 50
#define LONGCLICK_MS 200
#define DOUBLECLICK_MS 300
#define CAPACITIVE_TOUCH_THRESHOLD 35
#define SINGLE_CLICK 1
#define DOUBLE_CLICK 2
#define TRIPLE_CLICK 3
#define LONG_CLICK 4
#define UNDEFINED_PIN 255
class Button2 {
protected:
byte pin;
byte state;
byte prev_state;
byte click_count = 0;
byte last_click_type = 0;
byte _pressedState;
bool is_capacitive = false;
unsigned long click_ms;
unsigned long down_ms;
bool longclick_detected_retriggerable;
uint16_t longclick_detected_counter;
bool longclick_detected = false;
bool longclick_detected_reported = false;
unsigned int debounce_time_ms;
unsigned int longclick_time_ms;
unsigned int doubleclick_time_ms;
unsigned int down_time_ms = 0;
bool pressed_triggered = false;
typedef std::function<void(Button2 &btn)> CallbackFunction;
#else
typedef void (*CallbackFunction)(Button2 &);
#endif
CallbackFunction pressed_cb = NULL;
CallbackFunction released_cb = NULL;
CallbackFunction change_cb = NULL;
CallbackFunction tap_cb = NULL;
CallbackFunction click_cb = NULL;
CallbackFunction long_cb = NULL;
CallbackFunction double_cb = NULL;
CallbackFunction triple_cb = NULL;
CallbackFunction longclick_detected_cb = NULL;
public:
Button2();
Button2(byte attachTo, byte buttonMode = INPUT_PULLUP, boolean isCapacitive = false, boolean activeLow = true);
void begin(byte attachTo, byte buttonMode = INPUT_PULLUP, boolean isCapacitive = false , boolean activeLow = true);
void setDebounceTime(unsigned int ms);
void setLongClickTime(unsigned int ms);
void setDoubleClickTime(unsigned int ms);
unsigned int getDebounceTime() const;
unsigned int getLongClickTime() const;
unsigned int getDoubleClickTime() const;
byte getAttachPin() const;
void setLongClickDetectedRetriggerable(bool retriggerable);
void reset();
void setChangedHandler(CallbackFunction f);
void setPressedHandler(CallbackFunction f);
void setReleasedHandler(CallbackFunction f);
void setTapHandler(CallbackFunction f);
void setClickHandler(CallbackFunction f);
void setDoubleClickHandler(CallbackFunction f);
void setTripleClickHandler(CallbackFunction f);
void setLongClickHandler(CallbackFunction f);
void setLongClickDetectedHandler(CallbackFunction f);
unsigned int wasPressedFor() const;
boolean isPressed() const;
boolean isPressedRaw() const;
byte getNumberOfClicks() const;
byte getClickType() const;
bool operator == (Button2 &rhs);
void loop();
private:
byte _getState();
#endif
Button2.cpp (from a lib )
Button2.cpp - Arduino Library to simplify working with buttons.
#include "Button2.h"
Button2::Button2() {
pin = UNDEFINED_PIN;
Button2::Button2(byte attachTo, byte buttonMode /* = INPUT_PULLUP */, boolean isCapacitive /* = false */, boolean activeLow /* = true */) {
begin(attachTo, buttonMode, isCapacitive, activeLow);
void Button2::begin(byte attachTo, byte buttonMode /* = INPUT_PULLUP */, boolean isCapacitive /* = false */, boolean activeLow /* = true */) {
pin = attachTo;
longclick_detected_retriggerable = false;
_pressedState = activeLow ? LOW : HIGH;
setDebounceTime(DEBOUNCE_MS);
setLongClickTime(LONGCLICK_MS);
setDoubleClickTime(DOUBLECLICK_MS);
if (!isCapacitive) {
pinMode(attachTo, buttonMode);
is_capacitive = true;
// state = activeLow ? HIGH : LOW;
state = _getState();
prev_state = state ;
void Button2::setDebounceTime(unsigned int ms) {
debounce_time_ms = ms;
void Button2::setLongClickTime(unsigned int ms) {
longclick_time_ms = ms;
void Button2::setDoubleClickTime(unsigned int ms) {
doubleclick_time_ms = ms;
unsigned int Button2::getDebounceTime() const {
return debounce_time_ms;
unsigned int Button2::getLongClickTime() const {
return longclick_time_ms;
unsigned int Button2::getDoubleClickTime() const {
return doubleclick_time_ms;
byte Button2::getAttachPin() const {
return pin;
bool Button2::operator == (Button2 &rhs) {
return (this==&rhs);
void Button2::setLongClickDetectedRetriggerable(bool retriggerable) {
longclick_detected_retriggerable = retriggerable;
void Button2::setChangedHandler(CallbackFunction f) {
change_cb = f;
void Button2::setPressedHandler(CallbackFunction f) {
pressed_cb = f;
void Button2::setReleasedHandler(CallbackFunction f) {
released_cb = f;
void Button2::setClickHandler(CallbackFunction f) {
click_cb = f;
void Button2::setTapHandler(CallbackFunction f) {
tap_cb = f;
void Button2::setLongClickHandler(CallbackFunction f) {
long_cb = f;
void Button2::setDoubleClickHandler(CallbackFunction f) {
double_cb = f;
void Button2::setTripleClickHandler(CallbackFunction f) {
triple_cb = f;
void Button2::setLongClickDetectedHandler(CallbackFunction f) {
longclick_detected_cb = f;
unsigned int Button2::wasPressedFor() const {
return down_time_ms;
boolean Button2::isPressed() const {
return (state == _pressedState);
boolean Button2::isPressedRaw() const {
return (digitalRead(pin) == _pressedState);
byte Button2::getNumberOfClicks() const {
return click_count;
byte Button2::getClickType() const {
return last_click_type;
byte Button2::_getState() {
byte state = 0;
if (!is_capacitive) {
state = digitalRead(pin);
int capa = touchRead(pin);
state = capa < CAPACITIVE_TOUCH_THRESHOLD ? LOW : HIGH;
#endif
return state;
void Button2::loop() {
if (pin != UNDEFINED_PIN) {
prev_state = state;
unsigned long now = millis();
// is button pressed?
if (state == _pressedState && prev_state != _pressedState) {
down_ms = now;
click_ms = down_ms;
// trigger pressed event (after debounce has passed)
} else if (state == _pressedState && !pressed_triggered && (now - down_ms >= debounce_time_ms)) {
pressed_triggered = true;
click_count++;
if (change_cb != NULL) change_cb (*this);
if (pressed_cb != NULL) pressed_cb (*this);
// is the button released?
} else if (state != _pressedState && prev_state == _pressedState) {
down_time_ms = now - down_ms;
// is it beyond debounce time?
if (down_time_ms >= debounce_time_ms) {
// trigger release
if (released_cb != NULL) released_cb (*this);
// trigger tap
if (tap_cb != NULL) tap_cb (*this);
// was it a longclick? (preceeds single / double / triple clicks)
if (down_time_ms >= longclick_time_ms) {
longclick_detected = true;
// is the button released and the time has passed for multiple clicks?
} else if (state != _pressedState && now - click_ms > doubleclick_time_ms) {
// was there a longclick?
if (longclick_detected) {
// was it part of a combination?
if (click_count == 1) {
last_click_type = LONG_CLICK;
if (long_cb != NULL) long_cb (*this);
longclick_detected_counter = 0;
// determine the number of single clicks
} else if (click_count > 0) {
switch (click_count) {
case 1:
last_click_type = SINGLE_CLICK;
if (click_cb != NULL) click_cb (*this);
case 2:
last_click_type = DOUBLE_CLICK;
if (double_cb != NULL) double_cb (*this);
case 3:
last_click_type = TRIPLE_CLICK;
if (triple_cb != NULL) triple_cb (*this);
click_count = 0;
click_ms = 0;
bool longclick_period_detected = now - down_ms >= (longclick_time_ms * (longclick_detected_counter + 1));
// check to see that the longclick_ms period has been exceeded and call the appropriate callback
if (state == _pressedState && longclick_period_detected && !longclick_detected_reported) {
longclick_detected_reported = true;
if (longclick_detected_retriggerable) {
// if it's retriggerable then we bump the counter and reset the "reported" flag (as the counter will stop the false trigger)
longclick_detected_counter++;
// longpress_detected_ms = now;
if (longclick_detected_cb != NULL)
longclick_detected_cb(*this);
void Button2::reset() {
click_count = 0;
down_time_ms = 0;
pressed_cb = NULL;
released_cb = NULL;
change_cb = NULL;
tap_cb = NULL;
click_cb = NULL;
long_cb = NULL;
double_cb = NULL;
triple_cb = NULL;
myFunctions.h
#pragma once
#ifndef myFUNCTIONS_H
#define myFUNCTIONS_H
//#ifndef DEF_ActionMessage
//#define DEF_ActionMessage
extern TFT_eSPI tft;
Button2 button_1, button_2, button_3, button_4;
void b_init();
class ActionBox;
class ActionBox {
public:
int BoxNum;
class ActionMessage {
public:
//ActionMessage();
//~ActionMessage();
//int BoxNum;
void UpdateMessage(int BoxNum);
ActionBox Box1;
ActionBox Box2;
ActionBox Box3;
ActionBox Box4;
ActionMessage Act;
Box1.BoxNum = 1;
Box2.BoxNum = 2;
Box3.BoxNum = 3;
Box4.BoxNum = 4;
void handler(Button2& btn) {
switch (btn.getClickType()) {
case SINGLE_CLICK:
case DOUBLE_CLICK:
Serial.print("double ");
Serial.print("click ");
Serial.print("on button #");
Serial.print((btn == button_1) ? "1" : "2");
if (btn == button_1) {
Serial.println("A clicked");
} else if (btn == button_2) {
Serial.println("B clicked");
//tft.drawRoundRect(46, 101, 30, 30, 4, TFT_RED);
} else if (btn == button_3) {
Serial.println("C clicked");
//sendCommand(CMD_PAUSE,0x01,2) ;
} else if (btn == button_4) {
Serial.println("D clicked");
ActionMessage();
~ActionMessage();
public:
int BoxNum;
void ActionMessage::UpdateMessage(int BoxNum);
class ActionBox {
public:
int BoxNum;
#endif
myFunctions.cpp
void ActionMessage::UpdateMessage(int BoxNum){
tft.fillRect(100, 75, 100, 20, TFT_CYAN);
tft.setCursor(100,75);
tft.print(BoxNum);
#define BUTTON_PIN_1 4
#define BUTTON_PIN_2 16
#define BUTTON_PIN_3 17
#define BUTTON_PIN_4 5
//Preferences preferences;
unsigned long now = 0;
byte counter = 0;
void longpress(Button2& btn) {
unsigned int time = btn.wasPressedFor();
Serial.print("You clicked ");
if (time > 1500) {
Serial.print("a really really long time.");
} else if (time > 1000) {
Serial.print("a really long time.");
} else if (time > 500) {
Serial.print("a long time.");
Serial.print("long.");
Serial.print(" (");
Serial.print(time);
Serial.println(" ms)");
void pressed(Button2& btn) {
counter++;
if (counter == 2) {
now = millis();
Serial.println("now!");
Serial.println("A pressed");
Serial.println("B pressed");
tft.drawRoundRect(46, 100, 30, 30, 4, TFT_RED);
tft.drawRoundRect(47, 102, 28, 28, 3, TFT_PINK);
Act.UpdateMessage (Box2.BoxNum);
tft.drawRoundRect(86, 101, 30, 30, 4, TFT_RED);
tft.drawRoundRect(86, 100, 30, 30, 4, TFT_RED);
tft.drawRoundRect(87, 102, 28, 28, 3, TFT_PINK);
Act.UpdateMessage (Box3.BoxNum);
tft.drawRoundRect(126, 101, 30, 30, 4, TFT_RED);
tft.drawRoundRect(126, 100, 30, 30, 4, TFT_RED);
tft.drawRoundRect(127, 102, 28, 28, 3, TFT_PINK);
Act.UpdateMessage (Box4.BoxNum);
void released(Button2& btn) {
counter--;
if (counter == 0) {
if (now != 0) {
Serial.print("Pressed for: ");
Serial.print(millis() - now);
Serial.println("ms");
now = 0;
tft.drawRoundRect(6, 101, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(6, 100, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(7, 102, 28, 28, 3, TFT_CYAN);
tft.drawRoundRect(46, 101, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(46, 100, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(47, 102, 28, 28, 3, TFT_CYAN);
tft.drawRoundRect(86, 101, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(86, 100, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(87, 102, 28, 28, 3, TFT_CYAN);
tft.drawRoundRect(126, 101, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(126, 100, 30, 30, 4, TFT_CYAN);
tft.drawRoundRect(127, 102, 28, 28, 3, TFT_CYAN);
void b_init() {
//preferences.begin("my-app", false);
delay(10);
button_1.begin(BUTTON_PIN_1);
button_1.setClickHandler(handler);
button_1.setDoubleClickHandler(handler);
button_1.setLongClickHandler(longpress);
button_1.setPressedHandler(pressed);
button_1.setReleasedHandler(released);
button_2.begin(BUTTON_PIN_2);
button_2.setClickHandler(handler);
button_2.setDoubleClickHandler(handler);
button_2.setLongClickHandler(longpress);
button_2.setPressedHandler(pressed);
button_2.setReleasedHandler(released);
button_3.begin(BUTTON_PIN_3);
button_3.setClickHandler(handler);
button_3.setDoubleClickHandler(handler);
button_3.setLongClickHandler(longpress);
button_3.setPressedHandler(pressed);
button_3.setReleasedHandler(released);
button_4.begin(BUTTON_PIN_4);
button_4.setClickHandler(handler);
button_4.setDoubleClickHandler(handler);
button_4.setLongClickHandler(longpress);
button_4.setPressedHandler(pressed);
button_4.setReleasedHandler(released);
void b_loop() {
button_1.loop();
button_2.loop();
