Hello, I am having a very confusing problem.
When I use some code (I will post that later in message), it comes with a very confusing error message.
CODE:
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
#include "SR04.h"
#include "tones.h"
#include "Talkie.h"
#include "Vocab_US_Large.h"
#include "Vocab_US_TI99.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
long toneVal;
int piezo = 3;
int fan = 10;
SR04 sr04 = SR04(ECHO_PIN, TRIG_PIN);
long a;
int button = 7;
int R = 4;
int G = 8;
int B = 2;
int state = 1;
int low = 50.96;
int med = 91.44;
int high = 160;
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
Talkie voice;
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
pinMode(button, INPUT);
pinMode(fan, OUTPUT);
pinMode(piezo, OUTPUT);
pinMode(R, OUTPUT);
pinMode(G, OUTPUT);
pinMode(B, OUTPUT);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
//close_alarm();
//not_close();
a = sr04.Distance();
theremin(a);
// if (a < 30.48) {
// state = 1;
// else if (a > 30.48) {
// state = 2;
// if(state == 1) {
// close_alarm(100);
// else {
// theremin();
int close_alarm(int duration) {
digitalWrite(fan, HIGH);
blink();
close_warning(duration);
digitalWrite(fan, LOW);
return;
void not_close() {
knob();
theremin();
return;
void theremin(int a) {
toneVal = map(a, 1, 30, 1500, 31);
if (toneVal > 100) {
tone(piezo, toneVal);;
else noTone(piezo);
void knob() {
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15);
void blink() {
digitalWrite(R, HIGH);
delay(50);
digitalWrite(R, LOW);
delay(50);
digitalWrite(G, HIGH);
delay(50);
digitalWrite(G, LOW);
delay(50);
digitalWrite(B, HIGH);
delay(50);
digitalWrite(B, LOW);
void close_warning(int time) {
delay(time);
tone(piezo, 250);
delay(time);
noTone(piezo);
delay(time);
tone(piezo, 650, 500);
delay(time);
noTone(piezo);
// voice.say(sp2_DANGER);
// voice.say(spt_YOU);
// voice.say(spt_ARE);
// voice.say(spt_TOO);
// voice.say(sp4_CLOSE);
ERROR MESSAGE:
C:\hi\hows\your\day\a_folder\Cool_code.ino: In function 'void loop()':
Cool_code:57:3: error: 'theremin' was not declared in this scope
theremin(a);
Cool_code:72:33: error: a function-definition is not allowed here before '{' token
Cool_code:80:20: error: a function-definition is not allowed here before '{' token
void not_close() {
Cool_code:86:24: error: a function-definition is not allowed here before '{' token
Cool_code:94:15: error: a function-definition is not allowed here before '{' token
void knob() {
Cool_code:101:16: error: a function-definition is not allowed here before '{' token
void blink() {
Cool_code:115:32: error: a function-definition is not allowed here before '{' token
Cool_code:129:3: error: expected '}' at end of input
exit status 1
I am sorry if this is a very dumb problem.
Thank you!
