system
#1
Connected servo to pin 9 and using code:
#include <ServoTimer1.h>
ServoTimer1 servo1;
ServoTimer1 servo2;
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Servo test!");
servo1.attach(10);
servo2.attach(9);
Serial.print("tick");
servo1.write(180);
servo2.write(0);
Serial.print("tock");
servo1.write(0);
servo2.write(180);
Getting error: error: ‘TICIE1’ was not declared in this scope
mem
#2
A solution is in this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1200932603
Why are you using that library?
system
#3
Just trying to run some samples wich use this library (mshield sample):
ServoTimer1 servo1;
ServoTimer1 servo2;
servo1.attach(10);
servo2.attach(9);
servo1.write(180);
servo2.write(0);
servo1.write(0);
servo2.write(180);
mem
#4
if you change
ServoTimer1 servo1;
ServoTimer1 servo2;
to :
#include <Servo.h>
Servo servo1;
Servo1 servo2;
it should work using the arduinio servo library without any other code change
