Error tmElements_t_ tm; does not name a type
SetTime.ino sketch to set the time of DS1307 RTC - created by Paul Stoffregen
github.com/PaulStoffregen/DS1307RTC/blob/master/examples/SetTime/SetTime.ino
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
  bool parse=false;
  bool config=false;
  // get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
    parse = true;
    // and configure the RTC with this info
    if (RTC.write(tm)) {
      config = true;
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(200);
  if (parse && config) {
    Serial.print("DS1307 configured Time=");
    Serial.print(__TIME__);
    Serial.print(", Date=");
    Serial.println(__DATE__);
  } else if (parse) {
    Serial.println("DS1307 Communication Error :-{");
    Serial.println("Please check your circuitry");
    Serial.print("Could not parse info from the compiler, Time=\"");
    Serial.print("\", Date=\"");
    Serial.print(__DATE__);
    Serial.println("\"");
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
// Not sure how to post error codes, so here goes
Arduino: 1.8.19 (Windows 10), Board: "Arduino MKR WiFi 1010"
In file included from C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino:8:0:
C:\Users\brin8\Documents\Arduino\libraries\DS1307RTC-1.4.1/DS1307RTC.h:19:22: error: 'tmElements_t' has not been declared
 static bool read(tmElements_t &tm);
C:\Users\brin8\Documents\Arduino\libraries\DS1307RTC-1.4.1/DS1307RTC.h:20:23: error: 'tmElements_t' has not been declared
 static bool write(tmElements_t &tm);
HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO:15:1: error: 'tmElements_t' does not name a type; did you mean 'timelib_month_t'?
tmElements_t tm;
timelib_month_t
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino: In function 'void setup()':
HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO:25:19: error: 'tm' was not declared in this scope
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino:25:19: note: suggested alternative: 'Pm'
               Pm
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino: In function 'bool getTime(const char*)':
HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO:58:3: error: 'tm' was not declared in this scope
tm.Hour = Hour;
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino:58:3: note: suggested alternative: 'Pm'
tm.Hour = Hour;
Pm
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino: In function 'bool getDate(const char*)':
HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO:75:3: error: 'tm' was not declared in this scope
tm.Day = Day;
C:\Arduino_Projects\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO\HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO.ino:75:3: note: suggested alternative: 'Pm'
tm.Day = Day;
Pm
HOW_TO_DO_DAILY_TASKS_WITH_ARDUINO:77:13: error: 'CalendarYrToTm' was not declared in this scope
Multiple libraries were found for "TimeLib.h"
Used: C:\Users\brin8\Documents\Arduino\libraries\TimeLib-master
Not used: C:\Users\brin8\Documents\Arduino\libraries\Time
exit status 1
One of these libraries seems to be out of date or is otherwise inapplicable to your board.
This is where the (edited) sketch from post #1 originated (SetTime Sketch):
It calls for installing these two libraries:
Thanks, I'll reinstall libraries and make sure I use latest revisons.
