Error trying to display NMEA gps data on Nokia 5110---SOLVED----
Hi!
I have spend two days so far, combing the web, and trying many different options.
My setup;
GPS board to Uno, with nokia 5110 display.
Code is for AGV ground vehicle.
I want to use the 5110 display to show current latitude, and longitude.
I am using the NMEA library (not TinyGPS, or TinyGPS++)
MY code is not compiling; the following error keeps getting kicked out:
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
gps_module_rev4.ino: In function 'void trackGPS()':
gps_module_rev4:69: error: argument of type 'float (NMEA::)()' does not match 'float'
gps_module_rev4:70: error: argument of type 'float (NMEA::)()' does not match 'float'
here is my code:
#include <PCD8544.h>
#include <nmea.h>
#include <Servo.h>
#undef abs
#undef round
int wpt = 0;
float dest_latitude;
float dest_longitude;
float lat_f, lon_f;
static char lat_c[14];
static char lon_c[14];
NMEA gps(GPRMC);  // GPS data connection to GPRMC sentence type
#define WPT_IN_RANGE_M 1
Servo esc;
Servo steering;
int gps_valid = 8;
int a=500; //adjustable delay
int steering_hi = 2127;
int esc_hi =1700;
int steering_low=985;
int esc_low =1000;
int steering_mid= 1500;
int esc_mid = 1520;
float dir;          // relative direction to destination
int servo_pos = steering_mid;
static const byte LCD_WIDTH = 84;
static const byte LCD_HEIGHT = 48;
static PCD8544 lcd;
  lcd.begin(LCD_WIDTH, LCD_HEIGHT);
  esc.attach(10);
  steering.attach(9);
  pinMode (gps_valid, OUTPUT);
  digitalWrite(gps_valid, LOW);
  trackWpts();
  trackGPS();
  lcd.setCursor(1, 0);
  lcd.print("-----GPS-----");
void trackGPS() {
  if (dest_latitude != 0 && dest_longitude != 0)
    if (Serial.available() > 0 ) {
      char c = Serial.read();
      if (gps.decode(c)) {
      if (gps.gprmc_status() == 'A') {
        digitalWrite(gps_valid, HIGH);
        lat_f=(gps.gprmc_latitude);
        lon_f=(gps.gprmc_longitude);
          dtostrf(lat_f,10,8,lat_c);
          dtostrf(lon_f,10,8,lon_c);
        lcd.setCursor(0,3);
        lcd.print("Signal Fix");
        lcd.setCursor(0,1);
       lcd.print(lat_c);
        lcd.setCursor(0,2);
        lcd.print(lon_c);
          // calculate relative direction to destination
          dir = gps.gprmc_course_to(dest_latitude, dest_longitude) - gps.gprmc_course();
          if (dir < 0)
            dir += 360;
          if (dir > 180)
            dir -= 360;
          if (dir < -75)
            forward_Left();
          else if (dir > 75)
            forward_Right();
            driveToTarget();
        lcd.setCursor(0,3);
        lcd.print("No GPS Fix");
          halt();
    halt();
void driveToTarget() {
  servo_pos = map(dir, -75, 75, steering_hi, steering_low);
  steering.writeMicroseconds(servo_pos);
  esc.writeMicroseconds(esc_hi);
  lcd.setCursor(0,4);
  lcd.print("drive");
  lcd.setCursor(0,5);
  lcd.print(dir);
  lcd.print("m to go");
// Movement Code
void halt()
    lcd.setCursor(0,4);
    lcd.print("halt ");
 esc.writeMicroseconds(esc_mid);
steering.writeMicroseconds(steering_mid);
void forward()
  lcd.setCursor(0,4);
  lcd.print(" fwd ");
void forward_Left()
  lcd.setCursor(0,4);
  lcd.print("left ");
 steering.writeMicroseconds(steering_hi);
 delay (a);
void forward_Right()
  lcd.setCursor(0,4);
  lcd.print("right");
 steering.writeMicroseconds(steering_low);
  delay (a);
/* DEFINE GPS WPTS HERE - Create more cases as needed */
void trackWpts() {
  switch(wpt) {
    case 0:
      dest_latitude = 40.756054;
      dest_longitude = -73.986951;
    case 1:
      dest_latitude = 37.775206;
      dest_longitude = -122.419209;
    default:
      dest_latitude = 0;
      dest_longitude = 0;
  if (gps.gprmc_distance_to(dest_latitude,dest_longitude,MTR) < WPT_IN_RANGE_M)
    wpt++;
I am forced to ask for help!!!
Sorry! LOL
I'm guessing here a little... what are "gps.gprmc_latitude" and "gps.gprmc_longitude" that you use? Are they actual variables or functions? If functions, instead of putting them in braces, try to put the braces after them like so:
        lat_f= gps.gprmc_latitude();
        lon_f= gps.gprmc_longitude();
SOB!!! Functions...............
That worked! LOL. I suck....
Thanks a lot! :grinning: :grinning:
Heh, I spot these things easily only because I've made the same mistake myself a hundred times :wink:
Yup!
The fun of teaching yourself code........
LOL!
