Error trying to print out values in an array
I am trying to learn to use an array of four switches as a starting point for a bigger project. All I want to do is read the value on each of the switches and print it out.
int PinCount[4]; // count array 4 elements
int SwitchPin[] = {A0, A1, A2, A3}; //Analog pins to be read
int val[4]; // Value of reading on each of the SwitchPins
int thisPin[4]; //Array number of SwitchPins
  for (int thisPin = 0; thisPin < PinCount; thisPin++) // Set each pin to input in turn
    pinMode(SwitchPin[thisPin], INPUT_PULLUP);
    for (int thisPin = 0; thisPin < PinCount; thisPin++)  //To count each pin in turn
      val[thisPin] = (analogRead(SwitchPin[thisPin]));//Read each value of each switchpin
    Serial.print("thisPin  ");
    Serial.println([thisPin]); // Print the number of the SwitchPin being read
    Serial.println(val[thisPin]); // Print the value of that pin
I get more error messages than the program is long.
I have read various tutorials to end up at this point but have obviously not understood or applied them properly,
PinCount is an array of numbers which the for does not understand.
for (int thisPin = 0; thisPin <=3; thisPin++)
thisPin[x] where x is the array cell value will produce an output.
declaring a variable whose scope is within the confines of the for and having a global of the same name will cause issue.
Why use analog pins for a switch input?
SCOPE: Scope of Variables in C++ - GeeksforGeeks
Arrays: C++ Arrays (tutorialspoint.com)
Here I declare a global array.
const int BufferCount = 60;
float CollectionPressure[BufferCount] = {0.0f};
Here I fill the array with stuff.
void fStoreAirPressure ( void *pvParemeters )
  int cellCount = 0;
  int Ticks     = 0;
  bool Filled   = false;
  const int ticksTrigger = 120; // triggered at 1 minute intervals
  for (;;)
    //triggered by BME which is triggered by the 1 minute hardware timer.
    xEventGroupWaitBits (eg, evtStoreAirPressure, pdTRUE, pdTRUE, portMAX_DELAY );
    xSemaphoreTake( sema_CollectPressure, portMAX_DELAY );
    if ( !Filled )
      CollectionPressure[cellCount] = x_eData.oPressure;
    if ( Filled )
      if ( Ticks == ticksTrigger )
      //shift contents left and insert new value at the end
      for ( int i = 0; i <= BufferCount - 2; i++ )
        CollectionPressure[i] = CollectionPressure[i + 1];
      CollectionPressure[BufferCount - 1] = x_eData.oPressure;
    Ticks++;
    if ( Ticks >= (ticksTrigger + 1) )
      Ticks = 1;
      cellCount++;
    if ( cellCount == (BufferCount - 1) )
      cellCount = 0;
      Filled = !Filled;
    xSemaphoreGive( sema_CollectPressure );
    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  } //for (;;)
  vTaskDelete( NULL );
} //void fStoreAirPressure ( void *pvParemeters )
Here I use the stuff from the array.
    for ( int j = 0; j < BufferCount; j++ )
      if ( CollectionPressure[j] != 0.0f )
        int yAdj = (int)CollectionPressure[j] - BaseLine;
        display.setCursor( CurrentX + (j + 10 ), CurrentY + yAdj );
        display.print( "-" );
        log_i( "pressure %f item %d", CollectionPressure[j], j );
Thank you. Your suggestion has allowed me to compile the code successfully. It still doesn't work as I want, but that is a another problem!
PS - I am using the analog pins because this is a test for a much larger project that will use many inputs and outputs.
Thanks again.
Tony
@t0ny First things first.
Do you understand the difference between an int and an array of ints?
Do you understand that this ↓
int PinCount[4];
does not do the same thing as this ↓ ?
int PinCount = 4;
The first one makes PinCount be an array of four numbers.
The second one makes PinCount be the number 4.
The difference is important.
From looking at the rest of your code, I really think you want PinCount to be the number 4. Why do I think this? Because of this line here:
in which you have this comparison
thisPin < PinCount
in which you have one number on the left, and so you will also need one number on the right.
This line ↓
is useless, and is the cause of at least some of the error messages you are getting. Why? Because you are declaring thisPin to be an array of four numbers, and then later in your code, you are re-declaring it as one number.
This here ↓
int thisPin = 0;
declares thisPin to be one number, and sets it to the number 0.
I'm not sure what you want this line ↑ to do. But, I'm pretty sure that it's the cause of at least one of your error messages.
Hello t0ny
If you do so it is highly recommended to take a view how to code in C++.
You will have In- and outputs. These can be organized within objects using the struc instruction. The struc will contain all relevant information to be excuted by a service/method/function or how ever you will call this.
These services/methods/functions will be coded once and operates with information provided by in-/output objects.
p.s.
This is the definition of the button object, used for each input.
struct BUTTON {             // has the following members
  byte pin;                 // port pin
  bool statusQuo;           // current state
  TIMER scan;               // see timer struct
Thanks.
I obviously have problems here, but when trying new things, who doesn't? I thought I understood what I was doing and have learned from this. I have rectified my mistakes and can use that knowledge in the future. This program is just a small learning project to do just that. The program is now doing what I expected it to do.
This is just a print to allow me to see which pin is being read at that time. As it is, I am getting spurious results from random pins occasionally. This has allowed me to see which ones are doing this. For example, the printout is not reporting the correct switch connected to that pin, that has been closed. I am working on that.
Thanks again for your help.
Tony
The program is working correctly. I am now using pins 50,51, 52 and 53. The values and pins are printed out but I am getting random readings at times on the pins when nothing is switched eg one pin will suddenly read high for no apparent reason and sometimes when I switch one pin another pin will also say that it has been pin, often an adjoining one but not always. This appears to be stray signals unless anyone has a better idea. Is there any way of shielding the pins or wires from this?
Hello t0ny
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
int PinCount[5]; // count array 4 elements
int SwitchPin[] = {50, 51, 52, 53}; //Analog pins to be read
int val[5]; // Value of reading on each of the SwitchPins
int thisPin[5]; //Array number of SwitchPins
int x;
byte y;
  for (int x = 0; thisPin < PinCount; x++) // Set each pin to input in turn
    pinMode(SwitchPin[x], INPUT_PULLUP);
    for ( byte y = 0; y <= 3 ; y++) //To assign a counter to each pin in turn
      //Serial.println(y);
      val[y] = (digitalRead(SwitchPin[y]));//Read each value of each switchpin
      delay (100); //debounce time
      Serial.print(SwitchPin[y]); // Print the number of the SwitchPin being read
      Serial.print(" Val thisPin ");
      Serial.println(val[y]); // Print the value of that pin
      if ((val [y]) == 1)
        Serial.println(" has changed");
        delay(10000); //to give me time to read the result
        val[y] = 0; //reset value to 0 for next reading
    delay(2000);
Thank you. I will post a schematic shortly. Essentially each pin can be connected to ground via a touch switch.
Hello t0ny
The usage of the delay() function will kill the desired realtime behaviour of the sketck. You have to "debounce" the mechanical contacts of the button by scanning the current state. Simply called: the sketch needs a button manager.
I realise that. Only one event can occur at any one time so that is acceptable. I have entered a debounce time at line 27 after the digital read.
If I get it running then I will remove all the delays and prints in the if((val[y]) section.
PS This was originally just a learning project to understand and apply arrays to multiple switches, one at a time. It has thrown up these problems, the spurious readings, that I am seeing if I can solve.
Further progress. When I disconnect all the wires connected to the pins then the readings are stable i.e. they all read 0. When I connect a wire then the reading become unstable. It seems as though the wires are acting as antennas/aerials. Even moving my hand near the wire seems to alter the reading. I need to shield the wires somehow.
Thanks for you attention.
Tony
↑ So, you declate PinCount as an array of five numbers.
But, then you try to use it as one number ↓ when setting up your pins as inputs.
What happens if you replace this ↓
int PinCount[5];
with this ↓ ? (Like both IdahoWalker and I tried to tell you)
int PinCount = 4;
