Error: undefined reference to a static variable
I'm getting an error of undefined reference to a static variable. Let see an example code:
test_static.ino:
class A
private:
   int a;
   static int b;
public:
   A(int i, int j) // Constructor
       a=i;
       b=j;
   void fun1()
       a++; // Acceptable
       b++; // Acceptable
   static void fun2()
       b++; // Acceptable
A obj(1,2);
In the previous code I need that fun2() be static so the variable 'b' should also be static, but I get the following compiler error:
C:\Users\ADMINI~1\AppData\Local\Temp\ccKAsoZy.ltrans0.ltrans.o: In function `_GLOBAL__sub_I_obj':
E:\_arduino\test_static/test_static.ino:15: undefined reference to `A::b'
collect2.exe: error: ld returned 1 exit status
If I remove static from the variable 'b' then the error changes to:
E:\_arduino\test_static\test_static.ino: In static member function 'static void A::fun2()':
test_static:10: error: invalid use of member 'A::b' in static member function
    int b;
test_static:24: error: from this location
        b++; // Acceptable
exit status 1
This is expected as fun2() is a static function and can only use static variables or functions.
If I remove static from fun2() then the code compiles without errors.
Any idea why I cannot use fun2() and 'b' as static ?
Because you have not yet allocated storage space for the static variable:
class A {
  private:
    int a;
    static int b;
  public:
    A(int i, int j)   {
      a = i;
      b = j;
    void fun1()   {
      a++; // Acceptable
      b++; // Acceptable
    static void fun2()   {
      b++; // Acceptable
int A::b;  // <-------- ALLOCATE MEMORY FOR THE STATIC VARIABLE ---------------
A obj(1, 2);
