Error upload code
Hello, my name is Dimitri and I started in the Arduino, here I tried to upload a code and here the error, thank you to answer me.
pinMode(13,OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Using proxy DIRECT
Using proxy DIRECT
Using proxy DIRECT
Using proxy DIRECT
Cordialement , Dimitri
(deleted)
I'm getting not same but similar error.
Here is my complete error log,
vrdude: Version 6.0.1, compiled on Jan 15 2015 at 12:42:51
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/vedant/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem1411
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Any help is appreciated.
Thanks.
I have been programming with the arduino uno and wanted to try the pro mini for a change.
So I have a pro mini with me and also the RS232 FTDI breakout board with me. i connected all the pins to their corresponding places and connected to the laptop, both the board and the pro mini light up, and the pro mini is blinking. the board is properly selected in the IDE and so are the drivers for the FTDI board.
But i tried uploading a blink program and it showed the following error.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x18
What should I do?
Did you try reversing the RX and TX lines.
Quite often that does the trick.
hello, I said that there is a shield easyvr 3 on the Arduino.
Arduino : 1.6.9 (Windows 7), Carte : "Arduino/Genuino Uno"
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
System wide configuration file is "C:\Users\ADMIN\Desktop\arduino-1.6.9\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3a
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
Hello, I unplugged the shield and I upload the code on the Arduino, it works, now anybody know how to transfer the voice recognition easycommander on Arduino code please
Maybe next time tell us you have a shield etc !
dimitrird:
Using Port : COM4
I wrote here
Ballscrewbob:
yes i did but it doesnt change anything. still the same error.
so I finally tried to make the pro mini work and turns out the issue couldnt be any pettier.
My solder joints of the pin header that connects the TTL to serial converter to the pro mini board wasn't gud.. SOO.. once that was sorted out. it works well. :slight_smile:
