Error upload sketch Arduino UNO Versi 1.8.3
Arduino: 1.8.3 (Windows 8.1), Board: "Arduino/Genuino Uno"
Sketch uses 3536 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 262 bytes (12%) of dynamic memory, leaving 1786 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x11
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x11
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1c
An error occurred while uploading the sketch
option enabled in File -> Preferences.
I've this problem.
Give me a solution please, thank's.
Did you enable the verbose output?
Try disconnecting the UNO from your Windows machine, reinstall the driver, connect it again and try the upload once again.
pylon:
Thanks, helpfull.
I've new problem, i try to automatic wifi configuration ESP8266 like this :
#define SSID "KOSAN 8"
#define PASS "458italy"
//#define Baud_Rate 115200
#define Delay_Time 5000
  Serial.begin(Baud_Rate);//inisialisasi serial
  Serial.println("AT");
  delay(2000);//menunggu 5 detik bisa ubah biar lebih cepat
  //sambungkan ke wifi
  Serial.println("AT+CWMODE=1");//mode wifi client
  delay(2000);//menunggu dengan interval 2 detik
  String cmd = "AT+CWJAP=\"";//at command konek ke wifi router
  cmd += SSID;//SSID diisi nama wifi
  cmd += "\",\"";
  cmd += PASS;//PASS diisi password wifi
  cmd += "\"";//simpelnya ya gini AT+CWJAP="SSID","PASS";
  Serial.println(cmd);//kirim at command ke esp8266
  delay(5000);//tunggu sampe 5 detik
  if(Serial.find("OK")){//respon dari esp8266
    Serial.println("WORK");
  }else{
    Serial.println("FAILED");
  //end sambungan ke wifi
but, the result failed , can u give me solution?
No, this is an Arduino forum. You might have more luck on an ESP8266 forum.
