Hi. I am having problems uploading code to my Arduino. Any fixes? Thanks
Sketch uses 656 bytes (0%) of program storage space. Maximum is 253,952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8,183 bytes for local variables. Maximum is 8,192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\Lizzie\AppData\Local\Temp\arduino_build_464113/sketch_dec06a.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\Lizzie\AppData\Local\Temp\arduino_build_464113/sketch_dec06a.ino.hex"
avrdude: writing flash (656 bytes):
Writing | ################################################## | 100% 0.10s
avrdude: 656 bytes of flash written
avrdude: verifying flash memory against C:\Users\Lizzie\AppData\Local\Temp\arduino_build_464113/sketch_dec06a.ino.hex:
avrdude: load data flash data from input file C:\Users\Lizzie\AppData\Local\Temp\arduino_build_464113/sketch_dec06a.ino.hex:
avrdude: input file C:\Users\Lizzie\AppData\Local\Temp\arduino_build_464113/sketch_dec06a.ino.hex contains 656 bytes
avrdude: reading on-chip flash data:
Reading | ################An error occurred while uploading the sketch
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x14 != 0x71
avrdude: verification error; content mismatch
avrdude done. Thank you.
