Error uploading code to arduino nano every
while uploading a code to nano every the following error appears.. please guide..
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Nano Every, ATMEGA328"
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp: In function 'void TIMER1_COMPA_vect()':
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:160:31: error: 'TCNT1' was not declared in this scope
handle_interrupts(_timer1, &TCNT1, &OCR1A);
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:160:31: note: suggested alternative: 'TCB1'
                           TCB1
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:160:39: error: 'OCR1A' was not declared in this scope
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp: In function 'void initISR(timer16_Sequence_t)':
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:206:5: error: 'TCCR1A' was not declared in this scope
 TCCR1A = 0;             // normal counting mode
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:206:5: note: suggested alternative: 'TCB1'
 TCB1
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:207:5: error: 'TCCR1B' was not declared in this scope
 TCCR1B = _BV(CS11);     // set prescaler of 8
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:207:5: note: suggested alternative: 'TCB1'
 TCB1
In file included from c:\users\amuvishu\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
             from c:\users\amuvishu\documents\arduinodata\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\interrupt.h:38,
             from C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:71:
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:207:18: error: 'CS11' was not declared in this scope
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:207:18: note: suggested alternative: 'B111'
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:208:5: error: 'TCNT1' was not declared in this scope
 TCNT1 = 0;              // clear the timer count
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:208:5: note: suggested alternative: 'TCB1'
 TCB1
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:214:5: error: 'TIFR1' was not declared in this scope
 TIFR1 |= _BV(OCF1A);     // clear any pending interrupts;
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:214:18: error: 'OCF1A' was not declared in this scope
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:215:5: error: 'TIMSK1' was not declared in this scope
 TIMSK1 |=  _BV(OCIE1A) ; // enable the output compare interrupt
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:215:5: note: suggested alternative: 'TIMERB1'
 TIMERB1
C:\Users\Amuvishu\Documents\Arduino\libraries\VarSpeedServo-master\VarSpeedServo.cpp:215:20: error: 'OCIE1A' was not declared in this scope
exit status 1
Error compiling for board Arduino Nano Every.
option enabled in File -> Preferences.
The code you didn't post isn't compatible with the board you are compiling for.
This is not an installation or troubleshooting issue.
thnk u.. appreciate it
