I actually want to upload a program to my Arduino Uno for making a BB-9E. Since I'm new to Arduino I can't understand what is wrong. Please help me out...
This is the code:
<p>/* The code was made by Tamás Imets for an Arduino UNO project
This code controls the BB-8 Droid from the Star Wars: The Force Awakens,
and works with Bluetooth RC Car application, using a HC-06 serial bluetooth module
See more details at instructables.com/member/Imetomi
Friday, December 25, 2015
*/</p><p>#include <servo.h>
#include <softwareserial.h>
#include <afmotor.h>
int command = 0; //incoming serial data</afmotor.h></softwareserial.h></servo.h></p><p>AF_DCMotor motor1(1, MOTOR12_64KHZ); //initialize motor1 that is connected to the M1 port, this motor moves forward and backward
AF_DCMotor motor2(2, MOTOR12_64KHZ); //motor2 is connected to M2 and this turns BB-8 left and right
AF_DCMotor motorhead(3); //this motor turns the head left or right</p><p>Servo head;
Serial.begin(9600); // set up Serial library at 9600 bps - this is the speed the serial interface will work all
head.attach(9); //attach servo to pin D9 or to servo2 on motor shield
motor1.setSpeed(255); //set default speed
motor2.setSpeed(255); //set default speed
motorhead.setSpeed(1); //the motor should spin very slowly
pinMode(13, OUTPUT); //connect here the blue LED
}</p><p>void loop() {
if (Serial.available() > 0) { //if the Arduino detects incoming data
// read the incoming byte:
command = Serial.read();
switch (command) //set different cases of the "command" variable
case 'S': {
motor1.run(RELEASE); // stopped
motor2.run(RELEASE); // stopped
command = '*';
} break;</p><p> case 'F': { //go forward
motor1.run(FORWARD);
} break;</p><p> case 'B': { //go backward
motor1.run(BACKWARD);
} break;</p><p> case 'R': { //spin right
motor2.run(FORWARD);
} break;</p><p> case 'L': { //spin left
motor2.run(BACKWARD);
} break;</p><p> case 'G': { //forward left
} break;</p><p> case 'I': { //forward right
} break;</p><p> case 'H': { //backward left
} break;</p><p> case 'J': { //backward right
} break;</p><p> case 'W': {
digitalWrite(13, HIGH); //lights on
} break;</p><p> case 'w': {
digitalWrite(13, LOW); //lights off
} break;</p><p> case 'U': {
motor1.setSpeed(180); //set lower speed
} break;</p><p> case 'u': {
motor1.setSpeed(255); //set max speed
} break;</p><p> case 'V': {
motorhead.run(FORWARD); //turn head left
} break;</p><p> case 'v': {
motorhead.run(RELEASE); //stop spinning
} break;</p><p> case 'X': {
motorhead.run(BACKWARD); //turn head right
} break;</p><p> case 'x': {
} break;</p><p> case '0': {
head.write(95); //basic servo state
} break;</p><p> case '1': {
head.write(50); //move servo
} break;</p><p> case '2': {
head.write(60); //move servo
} break;</p><p> case '3': {
head.write(70); //move servo
} break;</p><p> case '4': {
head.write(80); //move servo
} break;</p><p> case '5': {
head.write(90); //move servo
} break;</p><p> case '6': {
head.write(95); //move servo
} break;</p><p> case '7': {
head.write(110); //move servo
} break;</p><p> case '8': {
head.write(120); //move servo
} break;</p><p> case '9': {
head.write(130); //move servo
} break;</p><p> case 'q': {
head.write(135); //move servo
} break;
//you can add more extra feautres by writing a case command (example: different lights, sound, etc...)
}</p>
Even on attaching and detaching the Motor Shield and Bluetooth module, it fails to upload.
I guess the softwareserial.h should be SoftwareSerial.h and same for servo.h(Should be Servo.h)
Anyways, here's a link to the Instructables site of the project for more details:
On my friend's computer, an error msg shows up stating that avrdude isn't responding and is out of sync. Another msg is related to stray '#'
Hoping for a prompt reply,
Thanks in Advance
Arpit Arun Kumaar
