Error uploading code
I don't know what d error is but it says "error uploading code toArduino genuino/uno".
Please I am tired I don't have a laptop I go to cyber cafe everyday starving myself just to get this code uploaded . I need d final solution to this problem of uploading to my board.
You need to post the error message.
All of it.
1-control cables
2-make sure you used last version of arduino
3-make sure your board is working and it is not too old
@meymuuun
(2)
Why the latest version of the IDE? I'm still on 1.8.5 and have no issues.
(3)
Boards can be old and still work :wink:
what board you use ? Is this board selected from ide/tools/boards menu?
what serial? Is this serial selected from ide/tools/port menu?
Are you using a chinese clone with ch340 usb interface? Did you install correctly driver?
sterretje:
The IDE versions around 1.8.5 had a bug that could make startup time of the IDE super slow:
This bug was fixed in Arduino IDE 1.8.6. On my computer, 1.8.5 takes a minute to load, which 1.8.9 takes 24 seconds. I hate it when I have to go back and use 1.8.5 for this reason.
I have not used newer version so can't compare :slight_smile:
