error uploading message attached...also should my board LED blink whenever its
on? thanks for your help....
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -built-in-libraries D:\Arduino\libraries -libraries C:\Users\tj\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\tj\AppData\Local\Temp\arduino_build_873778 -warnings=none -build-cache C:\Users\tj\AppData\Local\Temp\arduino_cache_491027 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -verbose D:\Arduino\examples\01.Basics\Blink\Blink.ino D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -built-in-libraries D:\Arduino\libraries -libraries C:\Users\tj\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\tj\AppData\Local\Temp\arduino_build_873778 -warnings=none -build-cache C:\Users\tj\AppData\Local\Temp\arduino_cache_491027 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=D:\Arduino\hardware\tools\avr -verbose D:\Arduino\examples\01.Basics\Blink\Blink.ino Using board 'uno' from platform in folder: D:\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: D:\Arduino\hardware\arduino\avr Detecting libraries used... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\sketch\Blink.ino.cpp" -o "nul" Generating function prototypes... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\sketch\Blink.ino.cpp" -o "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\preproc\ctags_target_for_gcc_minus_e.cpp" "D:\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\preproc\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "D:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\sketch\Blink.ino.cpp" -o "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\sketch\Blink.ino.cpp.o" Compiling libraries... Compiling core... Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring_pulse.S.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\WInterrupts.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\hooks.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring_analog.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring_digital.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring_pulse.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\wiring_shift.c.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\CDC.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\HardwareSerial.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\HardwareSerial0.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\HardwareSerial1.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\HardwareSerial2.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\HardwareSerial3.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\IPAddress.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\PluggableUSB.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\Print.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\Stream.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\Tone.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\USBCore.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\WMath.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\WString.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\abi.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\main.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\new.cpp.o Using previously compiled file: C:\Users\tj\AppData\Local\Temp\arduino_build_873778\core\core.a Archiving built core (caching) in: C:\Users\tj\AppData\Local\Temp\arduino_cache_491027\core\core_arduino_avr_uno_fd040c28ca717db04400ddff4ecd4334.a Linking everything together... "D:\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/Blink.ino.elf" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778\sketch\Blink.ino.cpp.o" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/core\core.a" "-LC:\Users\tj\AppData\Local\Temp\arduino_build_873778" -lm "D:\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/Blink.ino.elf" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/Blink.ino.eep" "D:\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/Blink.ino.elf" "C:\Users\tj\AppData\Local\Temp\arduino_build_873778/Blink.ino.hex" Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3f avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3f Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
An Arduino comes pre-loaded with the blink sketch. When you connect it to the computer, the power LED should be on and the pin13 LED will first give three short flashed after which it will start blinking (one second on, one second off).
Have you selected the correct com port under tools -> port in the IDE menu?
thank you very much...had to install the FTDI drivers and now see the port...upload worked without an error.. :)
