Error uploading port COM3
Can anyone help me with this error,please
The error message is :
Arduino: 1.8.5 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 9600”
Archiving built core (caching) in: C:\Users\ramu\AppData\Local\Temp\arduino_cache_414665\core\core_esp8266_esp8266_nodemcuv2_CpuFrequency_80,FlashSize_4M1M,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_9600_fd2e494a23fa54dc98666000b92b2df7.a
Sketch uses 265060 bytes (25%) of program storage space. Maximum is 1044464 bytes.
Global variables use 34984 bytes (42%) of dynamic memory, leaving 46936 bytes for local variables. Maximum is 81920 bytes.
Uploading 269200 bytes from C:\Users\ramu\AppData\Local\Temp\arduino_build_232985/ESP8266_Standalone.ino.bin to flash at 0x00000000
… [ 30% ]
… [ 60% ]
… [ 91% ]
…An error occurred while uploading the sketch
“Show verbose output during compilation”
option enabled in File → Preferences.
I take it you are programming an 8266 , you have the correct voltage levels for it and the pins Set correctly for programming and not floating . You have selected “8266 thing” in your boards .
Restart everything and try again .
