Error Uploading ~ Serial Port 'COM 1' not found
Dear All,
I've trouble when uploading sketch, it say :
"Serial Port 'COM 1' Not found, Did you select the right one from Tools > Serial Port menu?"
I've click "Tools" then see the "Serial Port", but "Serial Port" is greyed out, i can't click it.
I've search in some forum, they said i must check and configure my COM & LPT Port in device manager.
But i don't see COM & LPT port in device manager.
Some people said it because, in recent laptop has no COM or LPT port.
What should i do to make arduino running in my laptop? :~
I use windows 7 64-bit with Asus A450L.
Thanks.
Up..Up..Up...
Help me please... =(
Not enough info in your thread... but read this, as it may or may not be related to your issue. no I do not have a solution yet.
http://forum.arduino.cc/index.php?topic=270176.0
What board are you using and where did you buy it from?
Have you tried another USB cable.
I use Arduino UNO, i buy it from electronic shop in my country (indonesia).
Yes, i i've tried another USB.
But, nothing happened.
Even, i just run Arduino uno from proteus then upload the sketch, the error still the same.
restart your pc, then try other usb port, its normal, happend alot
chichara:
Attach a picture of the board you're using.
May be you should try with another PC or laptop..
Some laptop not support LPT & COM..
