Error uploading sketch
Hello everyone, I am a bit confused because when I tried to upload the code, it didn't show any errors, but the problem is that it didn't upload to Arduino. I will share two codes with you. The first one is the code that I can upload, and the second one is the code that I cannot upload. The only thing I implemented for the second code is a percentage of the variables on the page 1.
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Encoder.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <MAX6675.h>
#define ONE_WIRE_BUS 10
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define thermoDO1 3
#define thermoCS1 4
#define thermoCLK1 5
#define thermoDO2 6
#define thermoCS2 7
#define thermoCLK2 8
#define thermoDO3 9
#define thermoCS3 10
#define thermoCLK3 11
#define thermoDO4 12
#define thermoCS4 13
#define thermoCLK4 14
MAX6675 thermocouple1(thermoCLK1, thermoCS1, thermoDO1);
MAX6675 thermocouple2(thermoCLK2, thermoCS2, thermoDO2);
MAX6675 thermocouple3(thermoCLK3, thermoCS3, thermoDO3);
MAX6675 thermocouple4(thermoCLK4, thermoCS4, thermoDO4);
const int sensorPin = A3;
const int sensorPin2 = A1;
const int waterTempPin = A2;
const int oilPressurePin = A7;
const int oilTempPin = A4;
const int buzzerPin = 8;
const int buttonPin = 4; // Pin del botón del encoder
int sensorValue1 = 0;
int sensorValue2 = 0;
float sensorVoltage1 = 0.0;
float pressure1 = 0.0;
float temp5 = 0.0;
float waterTemp = 0.0;
float oilPressure = 0.0;
float oilTemp = 0.0;
float sensorVoltage2 = 0.0;
float pressure2 = 0.0;
const float voltageMin = 0.5;
const float voltageMax = 4.5;
const float pressureMax = 1600;
enum State {
  MENU_VERTICAL,
  PAGINA
State currentState = MENU_VERTICAL;
unsigned long lastButtonPress = 0;
const unsigned long debounceDelay = 200; // Ajusta el tiempo de debounce
const int encoderThreshold = 5; // Número de pasos del encoder para considerar un cambio
bool buttonWasPressed = false;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Encoder encoder(2, 3);
int lastPosition = 0;
int currentPage = 0;
const int menuSections = 5;
const unsigned char PROGMEM imagen[] = {
  0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc,
	0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
	0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
	0x81, 0xfe, 0xff, 0x81, 0xf8, 0xf1, 0xbf, 0xf0, 0x7f, 0xfe, 0x0c, 0xff, 0x87, 0xf8, 0xfe, 0x01,
	0x81, 0xfe, 0xff, 0xc3, 0xfc, 0xf9, 0xbf, 0xf0, 0x7f, 0xef, 0x0d, 0xff, 0xc7, 0xf9, 0xff, 0x81,
	0x81, 0xc0, 0xe0, 0xe7, 0x86, 0xf9, 0x87, 0x80, 0x07, 0x07, 0x99, 0xe1, 0xc7, 0x01, 0xe0, 0x01,
	0x81, 0xfe, 0xff, 0xc7, 0x06, 0xfd, 0x87, 0x80, 0x07, 0x03, 0xf1, 0xff, 0xc7, 0xf9, 0xff, 0x01,
	0x81, 0xfe, 0xff, 0x87, 0x06, 0xdf, 0x87, 0x80, 0x07, 0x01, 0xe1, 0xff, 0x87, 0xf8, 0xff, 0x81,
	0x81, 0xc0, 0xfc, 0x17, 0x86, 0xcf, 0x87, 0x80, 0x07, 0x01, 0xe1, 0xfc, 0x37, 0x00, 0x07, 0x81,
	0x81, 0xc0, 0xef, 0xf3, 0xfc, 0xcf, 0x87, 0x80, 0x07, 0x01, 0xe1, 0xef, 0xf7, 0xf9, 0xc3, 0x81,
	0x81, 0xc0, 0xe3, 0xe1, 0xf8, 0xc7, 0x87, 0x80, 0x07, 0x01, 0xe1, 0xe7, 0xe7, 0xfc, 0xff, 0x01,
	0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x80, 0x3f, 0xe1, 0xff, 0x0f, 0x0f, 0xf8, 0x03, 0xff, 0xf0, 0x6f, 0xfc, 0x3f, 0xc7, 0xf0, 0x01,
	0x80, 0x3f, 0xf1, 0xff, 0x1f, 0x0f, 0xfe, 0x03, 0xff, 0x78, 0xef, 0xfe, 0x3f, 0xcf, 0xf8, 0x01,
	0x80, 0x38, 0x79, 0xc0, 0x1f, 0x8e, 0x0e, 0x00, 0x38, 0x3c, 0xcf, 0x0e, 0x38, 0x0f, 0x00, 0x01,
	0x80, 0x3f, 0xf1, 0xfe, 0x33, 0x8f, 0xfe, 0x00, 0x38, 0x1d, 0x8f, 0xfe, 0x3f, 0xcf, 0xf8, 0x01,
	0x80, 0x3f, 0xe1, 0xfe, 0x33, 0xcf, 0xfc, 0x00, 0x38, 0x1f, 0x0f, 0xfc, 0x3f, 0xc7, 0xfc, 0x01,
	0x80, 0x3f, 0x05, 0xc0, 0x7f, 0xcf, 0xe1, 0x00, 0x38, 0x0f, 0x0f, 0xe1, 0xb8, 0x00, 0x3c, 0x01,
	0x80, 0x3b, 0xfd, 0xff, 0x61, 0xee, 0xff, 0x00, 0x38, 0x0e, 0x0f, 0x7f, 0xbf, 0xce, 0x1c, 0x01,
	0x80, 0x39, 0xf9, 0xff, 0x61, 0xee, 0x3e, 0x00, 0x38, 0x0e, 0x0f, 0x3f, 0x3f, 0xc7, 0xf8, 0x01,
  // Aquí va la información de la imagen en formato byte
const unsigned char PROGMEM brake_temp[] = {
  0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc,
	0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
	0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
	0x83, 0x9c, 0x31, 0x13, 0x81, 0x0e, 0x73, 0x82, 0x4e, 0x70, 0xc4, 0x4e, 0x07, 0x11, 0xc9, 0x39,
	0x82, 0x12, 0x49, 0x91, 0x01, 0x08, 0x41, 0x02, 0x48, 0x49, 0x26, 0x44, 0x04, 0x92, 0x09, 0x11,
	0x83, 0x9c, 0x49, 0x51, 0x01, 0x0e, 0x71, 0x02, 0x4e, 0x71, 0x25, 0x44, 0x07, 0x12, 0xcf, 0x11,
	0x82, 0x14, 0x49, 0x31, 0x01, 0x08, 0x41, 0x02, 0x48, 0x51, 0x24, 0xc4, 0x05, 0x12, 0x49, 0x11,
	0x82, 0x12, 0x31, 0x11, 0x01, 0xce, 0x41, 0x02, 0x48, 0x48, 0xc4, 0x44, 0x04, 0x91, 0x89, 0x11,
	0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0x80, 0x70, 0xc3, 0x12, 0x04, 0x39, 0xce, 0x02, 0x41, 0xc3, 0x0c, 0x48, 0x1c, 0x47, 0x24, 0xe1,
	0x80, 0x49, 0x24, 0x94, 0x04, 0x21, 0x04, 0x02, 0x41, 0x24, 0x92, 0x50, 0x12, 0x48, 0x24, 0x41,
	0x80, 0x79, 0xe4, 0x18, 0x04, 0x39, 0xc4, 0x02, 0x41, 0xe7, 0x90, 0x60, 0x1c, 0x4b, 0x3c, 0x41,
	0x80, 0x49, 0x24, 0x94, 0x04, 0x21, 0x04, 0x02, 0x41, 0x24, 0x92, 0x50, 0x14, 0x49, 0x24, 0x41,
	0x80, 0x71, 0x23, 0x12, 0x07, 0x39, 0x04, 0x02, 0x41, 0xc4, 0x8c, 0x48, 0x12, 0x46, 0x24, 0x41,
const unsigned char PROGMEM spoon[] PROGMEM = {
 0xff, 0xff, 0xff, 0xff, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0xf0, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0xc0, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xf8, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xf0, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xe0, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xe0, 0x7f, 0xfe, 0x03, 0xfc, 0x0f, 0xe0,
	0xff, 0xff, 0xc0, 0x00, 0x00, 0x03, 0x80, 0x07, 0xff, 0x80, 0x3f, 0xf8, 0x01, 0xfc, 0x0f, 0xc0,
	0xff, 0xff, 0x80, 0x00, 0x00, 0x03, 0x00, 0x01, 0xfe, 0x00, 0x1f, 0xf0, 0x00, 0xfc, 0x07, 0xc0,
	0xff, 0xff, 0x80, 0x00, 0x00, 0x03, 0x00, 0x01, 0xfc, 0x00, 0x1f, 0xe0, 0x00, 0xfc, 0x07, 0xc0,
	0xff, 0xff, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0xf8, 0x00, 0x0f, 0xc0, 0x00, 0x78, 0x07, 0xc0,
	0xff, 0xfe, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0xf0, 0x00, 0x0f, 0x80, 0x00, 0x78, 0x07, 0xc1,
	0xff, 0xfe, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0xf0, 0x00, 0x0f, 0x80, 0x00, 0x78, 0x07, 0x81,
	0xff, 0xfc, 0x00, 0x06, 0x00, 0x02, 0x03, 0x80, 0xe0, 0x3c, 0x07, 0x01, 0xe0, 0x38, 0x03, 0x81,
	0xff, 0xfc, 0x00, 0x3f, 0x80, 0x02, 0x07, 0xc0, 0xc0, 0x7c, 0x06, 0x03, 0xe0, 0x38, 0x03, 0x81,
	0xff, 0xf8, 0x00, 0x7f, 0xc0, 0x02, 0x07, 0xc0, 0xc0, 0xfc, 0x06, 0x07, 0xe0, 0x30, 0x03, 0x83,
	0xff, 0xf8, 0x00, 0x7f, 0xc0, 0x02, 0x07, 0xc0, 0xc0, 0xfe, 0x06, 0x07, 0xf0, 0x30, 0x03, 0x03,
	0xff, 0xf8, 0x00, 0x7f, 0xc0, 0x00, 0x07, 0xc0, 0x81, 0xfe, 0x04, 0x0f, 0xf0, 0x30, 0x03, 0x03,
	0xff, 0xf0, 0x00, 0x7f, 0xff, 0xfc, 0x0f, 0x81, 0x81, 0xfc, 0x04, 0x0f, 0xe0, 0x30, 0x01, 0x03,
	0xff, 0xf0, 0x00, 0x7f, 0xff, 0xfc, 0x0f, 0x01, 0x81, 0xfc, 0x0c, 0x0f, 0xe0, 0x60, 0x01, 0x03,
	0xff, 0xf0, 0x00, 0x3f, 0xff, 0xfc, 0x00, 0x03, 0x01, 0xfc, 0x08, 0x0f, 0xe0, 0x60, 0x00, 0x07,
	0xff, 0xf0, 0x00, 0x1f, 0xff, 0xfc, 0x00, 0x03, 0x03, 0xfc, 0x08, 0x1f, 0xe0, 0x60, 0x40, 0x07,
	0xff, 0xe0, 0x00, 0x07, 0xff, 0xf8, 0x00, 0x07, 0x03, 0xfc, 0x08, 0x1f, 0xe0, 0x60, 0x40, 0x07,
	0xff, 0xe0, 0x00, 0x01, 0xff, 0xf8, 0x00, 0x0f, 0x03, 0xf8, 0x18, 0x1f, 0xc0, 0xe0, 0xc0, 0x07,
	0xff, 0xe0, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x1f, 0x03, 0xf8, 0x18, 0x1f, 0xc0, 0xc0, 0xc0, 0x07,
	0xff, 0xe0, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x3f, 0x03, 0xf8, 0x18, 0x1f, 0xc0, 0xc0, 0xe0, 0x0f,
	0xff, 0xe0, 0x00, 0x00, 0x07, 0xf8, 0x1f, 0xff, 0x03, 0xf0, 0x38, 0x1f, 0x81, 0xc0, 0xe0, 0x0f,
	0xff, 0xe0, 0x00, 0x00, 0x03, 0xf0, 0x3f, 0xff, 0x01, 0xe0, 0x38, 0x1f, 0x01, 0xc0, 0xe0, 0x0f,
	0xff, 0xe0, 0x00, 0x00, 0x01, 0xf0, 0x3f, 0xff, 0x01, 0xc0, 0x78, 0x0e, 0x03, 0xc1, 0xe0, 0x0f,
	0xff, 0xe0, 0x00, 0x00, 0x01, 0xf0, 0x3f, 0xff, 0x00, 0x00, 0x78, 0x00, 0x03, 0x81, 0xf0, 0x1f,
	0xff, 0xf0, 0x00, 0x00, 0x00, 0xf0, 0x3f, 0xff, 0x00, 0x00, 0xf8, 0x00, 0x07, 0x81, 0xf0, 0x1f,
	0xff, 0xf0, 0x00, 0x00, 0x00, 0xe0, 0x3f, 0xff, 0x80, 0x01, 0xf8, 0x00, 0x0f, 0x81, 0xf0, 0x1f,
	0xff, 0xf0, 0x00, 0x00, 0x00, 0xe0, 0x7f, 0xff, 0x80, 0x03, 0xfc, 0x00, 0x1f, 0x81, 0xf0, 0x1f,
	0xff, 0xf8, 0x00, 0x00, 0x00, 0xe0, 0x7f, 0xff, 0xc0, 0x07, 0xfe, 0x00, 0x3f, 0x03, 0xf0, 0x1f,
	0xff, 0xfc, 0x00, 0x00, 0x00, 0x60, 0x7f, 0xff, 0xe0, 0x0f, 0xff, 0x00, 0x7f, 0x83, 0xf8, 0x3f,
	0xff, 0xfe, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xfc, 0x3f, 0xff, 0xe1, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xc0, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xf8, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xfe, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f,
	0xff, 0xff, 0xff, 0x80, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0xc0, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0xe0, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xf0, 0x00, 0xff, 0xe0, 0x01, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xf0, 0x00, 0xff, 0xe0, 0x03, 0xf8, 0x1e, 0x00, 0xfe, 0x03, 0xc0, 0x06, 0x00, 0x0e, 0x07, 0xff,
	0xf0, 0x00, 0xff, 0xc0, 0x03, 0xe0, 0x0e, 0x00, 0x38, 0x01, 0xc0, 0x06, 0x00, 0x1c, 0x03, 0xff,
	0xe0, 0x00, 0xff, 0xc0, 0x03, 0xc0, 0x0e, 0x00, 0x30, 0x01, 0xc0, 0x02, 0x00, 0x18, 0x01, 0xff,
	0xe0, 0x00, 0x7f, 0x80, 0x07, 0xc0, 0x0c, 0x00, 0x20, 0x41, 0xc0, 0x06, 0x00, 0x10, 0x01, 0xff,
	0xe0, 0x00, 0x3e, 0x00, 0x07, 0x87, 0x0c, 0x3c, 0x21, 0xe0, 0x83, 0x87, 0xc3, 0xf0, 0xe1, 0xff,
	0xe0, 0x00, 0x18, 0x00, 0x0f, 0x83, 0xfc, 0x3c, 0x01, 0xe0, 0x87, 0x87, 0xc3, 0xe0, 0xff, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x7c, 0x38, 0x03, 0xe1, 0x87, 0x0f, 0xc3, 0xe0, 0x1f, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x38, 0x00, 0x03, 0xe1, 0x80, 0x0f, 0x83, 0xe0, 0x07, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x1f, 0x80, 0x18, 0x00, 0x87, 0xe1, 0x00, 0x1f, 0x87, 0xf0, 0x07, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x18, 0x00, 0x87, 0xe1, 0x00, 0x1f, 0x87, 0xf8, 0x03, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x18, 0x03, 0x87, 0xc3, 0x00, 0x0f, 0x87, 0xff, 0x03, 0xff,
	0xf0, 0x00, 0x00, 0x00, 0xff, 0xfe, 0x10, 0x7f, 0x87, 0x83, 0x0e, 0x1f, 0x07, 0xff, 0x87, 0xff,
	0xf0, 0x00, 0x00, 0x01, 0xfe, 0x1e, 0x10, 0xff, 0x83, 0x06, 0x0e, 0x1f, 0x07, 0x83, 0x87, 0xff,
	0xf0, 0x00, 0x00, 0x01, 0xfe, 0x00, 0x30, 0xff, 0x80, 0x06, 0x1e, 0x1f, 0x0f, 0x80, 0x07, 0xff,
	0xf8, 0x00, 0x00, 0x07, 0xfe, 0x00, 0x30, 0xff, 0xc0, 0x0e, 0x1e, 0x1f, 0x0f, 0xc0, 0x0f, 0xff,
	0xfc, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x61, 0xff, 0xc0, 0x3c, 0x1e, 0x1e, 0x0f, 0xc0, 0x1f, 0xff,
	0xfe, 0x00, 0x00, 0x1f, 0xff, 0x81, 0xfd, 0xff, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x7f, 0xff,
	0xff, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff
const unsigned char PROGMEM civic[] PROGMEM = {
	0xff, 0xff, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xff, 0x0f, 0xff, 0xdf, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xff, 0xf8, 0xf0, 0x00, 0xe0, 0x00, 0x00, 0x01, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf8, 0x07, 0x04, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf3, 0x98, 0x08, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf0, 0x00, 0x18, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf0, 0x00, 0x10, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf1, 0x00, 0x30, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf2, 0x3f, 0xa3, 0xff, 0x90, 0x00, 0x70, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xf4, 0x7f, 0x23, 0xff, 0x92, 0x01, 0xfe, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xe8, 0xff, 0x47, 0xe0, 0x93, 0x01, 0xff, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xd9, 0xfe, 0x47, 0xc0, 0x1b, 0x00, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xd1, 0xfe, 0xcf, 0xa0, 0x09, 0x80, 0x60, 0x80, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff,
	0xff, 0xb3, 0xfe, 0x8f, 0x80, 0x09, 0x80, 0x40, 0xc0, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff,
	0xff, 0x63, 0xfc, 0x8f, 0xc0, 0x09, 0x80, 0xc0, 0x40, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff,
	0xff, 0x47, 0xfd, 0x9f, 0x40, 0x0c, 0xc0, 0x00, 0x20, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff,
	0xfe, 0xc7, 0xfd, 0x9e, 0xc7, 0xf4, 0xc3, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff,
	0xfd, 0xc0, 0xf9, 0x00, 0xcf, 0xf6, 0x8f, 0xfe, 0x10, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff,
	0xf9, 0xe0, 0x01, 0x01, 0xcc, 0x36, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff,
	0xfb, 0xfc, 0x03, 0x01, 0xcf, 0xc6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
	0xf0, 0x07, 0xf3, 0x00, 0x07, 0xe1, 0xf1, 0xf8, 0x0f, 0xff, 0xff, 0xfe, 0x00, 0x7f, 0xff, 0xff,
	0xe0, 0x00, 0x03, 0xff, 0x00, 0x03, 0xfe, 0x7f, 0x80, 0xff, 0xff, 0xff, 0xe1, 0x07, 0xff, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xcf, 0xf0, 0x1f, 0xc0, 0x00, 0x3c, 0x70, 0xff, 0xff,
	0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf9, 0xff, 0x07, 0xf0, 0x00, 0x03, 0x1f, 0x1f, 0xff,
	0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x73, 0xc0, 0xff, 0xf0, 0x00, 0xc7, 0xe7, 0xff,
	0xcf, 0xff, 0xef, 0xc0, 0x00, 0x00, 0x00, 0x1f, 0xc8, 0x38, 0x7f, 0xff, 0x00, 0x32, 0x79, 0xff,
	0xcf, 0xff, 0xef, 0xff, 0xff, 0xe6, 0x00, 0x03, 0xf6, 0x03, 0x1f, 0xff, 0xe0, 0x0d, 0x0e, 0x7f,
	0xdf, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xf9, 0x00, 0xcf, 0xff, 0xfc, 0x06, 0x83, 0x3f,
	0x9f, 0xff, 0xef, 0xff, 0xff, 0xef, 0xff, 0xff, 0xfe, 0xc0, 0x37, 0xff, 0xff, 0x03, 0xc1, 0xdf,
	0x9f, 0xff, 0xff, 0xff, 0xff, 0xef, 0xbf, 0xff, 0xe2, 0x7f, 0xff, 0xff, 0xff, 0xc1, 0xc1, 0xef,
	0xbf, 0xff, 0xff, 0xff, 0xff, 0xef, 0x63, 0xff, 0x80, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xce, 0x0f,
	0xb8, 0xff, 0xff, 0xff, 0xff, 0xef, 0x80, 0xff, 0x00, 0x7c, 0x01, 0xff, 0xff, 0xff, 0xf3, 0xd7,
	0x30, 0x7f, 0xff, 0xff, 0xff, 0xef, 0x00, 0x7f, 0x70, 0x07, 0x18, 0xff, 0xff, 0xff, 0xfd, 0xf7,
	0x66, 0x3f, 0xdf, 0xff, 0xff, 0xef, 0x1c, 0x3e, 0x7f, 0x01, 0x8c, 0x2f, 0xff, 0xff, 0xe9, 0x83,
	0xc8, 0x3f, 0xdf, 0xff, 0xff, 0xee, 0x20, 0x00, 0x0f, 0x60, 0xcf, 0x80, 0x00, 0x00, 0x02, 0x3b,
	0xc8, 0x3f, 0xdf, 0xff, 0xff, 0xec, 0x60, 0x30, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x04, 0x69,
	0xdd, 0x10, 0x00, 0x00, 0x00, 0x0c, 0x56, 0x10, 0x1f, 0xfc, 0x00, 0xff, 0xff, 0xff, 0xfb, 0x80,
	0x95, 0x98, 0x00, 0x00, 0x00, 0x00, 0xd6, 0x10, 0x00, 0x0f, 0xff, 0xca, 0x00, 0x00, 0x00, 0x00,
	0x95, 0x0f, 0xdf, 0xff, 0x00, 0x04, 0xf6, 0x0b, 0xff, 0xff, 0xdc, 0x00, 0x0f, 0xff, 0xff, 0xfe,
	0x90, 0x0f, 0xff, 0xff, 0xff, 0xfc, 0x96, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe,
	0x1a, 0x8f, 0xef, 0xc0, 0x00, 0x08, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe,
	0x1f, 0x87, 0x00, 0x00, 0x00, 0x00, 0xa9, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd, 0xfe,
	0x1f, 0x80, 0x00, 0x00, 0x00, 0x00, 0xaf, 0x0f, 0xff, 0xe0, 0x02, 0x00, 0x00, 0x00, 0x06, 0x02,
	0x9a, 0x80, 0x00, 0x00, 0x00, 0x00, 0xbf, 0x07, 0xff, 0xc0, 0x06, 0x00, 0x00, 0x00, 0x02, 0x06,
	0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0x07, 0xff, 0xc0, 0x0f, 0x46, 0x58, 0x21, 0x82, 0x06,
	0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa9, 0x07, 0xff, 0xc0, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x06,
	0x90, 0x00, 0x7b, 0xfe, 0x00, 0x00, 0x80, 0x07, 0xff, 0xe0, 0x03, 0x06, 0x08, 0x21, 0x04, 0x06,
	0x97, 0x00, 0x00, 0x1f, 0xff, 0xf8, 0x96, 0x07, 0xff, 0xff, 0xf3, 0x00, 0x00, 0x00, 0x0f, 0xfd,
	0x84, 0x07, 0xff, 0xff, 0x00, 0x00, 0xb6, 0x07, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x0f, 0xff,
	0x81, 0x01, 0xff, 0xff, 0xff, 0xf8, 0xd6, 0x05, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x06, 0x00,
	0xc4, 0x00, 0x0f, 0xff, 0xff, 0xf8, 0xd6, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xfe,
	0xe2, 0x00, 0xc0, 0x00, 0x07, 0xf8, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0x06,
	0xe0, 0x01, 0xff, 0xff, 0xf0, 0x00, 0x60, 0x07, 0xff, 0xe0, 0x07, 0x60, 0x00, 0x00, 0x3a, 0x02,
	0x00, 0x00, 0x00, 0x3f, 0xff, 0xfc, 0x38, 0x07, 0xff, 0xe0, 0x07, 0x80, 0x00, 0x00, 0x1f, 0xfe,
	0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xe0, 0x00, 0x60, 0x00, 0x00, 0x00, 0x01,
	0xff, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xe0, 0x00, 0x7f,
	0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
	0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
void mostrarMenuVertical() {
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  for (int i = 0; i < menuSections; i++) {
    if (i == currentPage) {
      display.fillRect(0, i * 12, SCREEN_WIDTH, 12, SSD1306_WHITE);
      display.setTextColor(SSD1306_BLACK);
    display.setCursor(10, i * 12);
    switch (i) {
      case 0:
       display.print("BRAKE BIAS");
      case 1:
       display.print("BRAKE TEMP");
      case 2:
       display.print("GAUGES");
      case 3:
        display.print("EMPTY");
      case 4:
  display.display();
void mostrarPagina(int pageNumber) {
  switch (pageNumber) {
    case 0:
      display.drawBitmap(0, 0, imagen, SCREEN_WIDTH, SCREEN_HEIGHT, SSD1306_WHITE);
      sensorValue1 = analogRead(sensorPin);
      sensorVoltage1 = sensorValue1 * (4.5 / 1023.0);
      pressure1 = (sensorVoltage1 >= voltageMin) ? ((sensorVoltage1 - voltageMin) / (voltageMax - voltageMin)) * pressureMax : 0.0;
      display.setCursor(40, 17);
      display.print(pressure1, 2);
      display.println(" PSI");
      sensorValue2 = analogRead(sensorPin2);
      sensorVoltage2 = sensorValue2 * (4.5 / 1023.0);
      pressure2 = (sensorVoltage2 >= voltageMin) ? ((sensorVoltage2 - voltageMin) / (voltageMax - voltageMin)) * pressureMax : 0.0;
      display.setCursor(40, 51);
      display.print(pressure2, 2);
    case 1:
      display.drawBitmap(0, 0, brake_temp, SCREEN_WIDTH, SCREEN_HEIGHT, SSD1306_WHITE);
      display.setCursor(10, 17);
      display.print(thermocouple1.getTemperature()); // Usa el método correcto
      display.println(" C");
      display.setCursor(73, 17);
      display.print(thermocouple2.getTemperature()); // Usa el método correcto
      display.setCursor(10, 49);
      display.print(thermocouple3.getTemperature()); // Usa el método correcto
      display.setCursor(73, 49);
      display.print(thermocouple4.getTemperature()); // Usa el método correcto
    case 2:
      sensors.requestTemperatures();
      temp5 = constrain(sensors.getTempCByIndex(0), -1000, 1000); // Corregido
      waterTemp = analogRead(waterTempPin) * 0.488;
      oilPressure = analogRead(oilPressurePin) * 0.488;
      oilTemp = analogRead(oilTempPin) * 0.488;
      display.setCursor(1, 2);
      display.setTextSize(1.8);
      display.print("EXHAUT TEMP: ");
      display.print(temp5);
      display.setCursor(1, 18);
      display.print("ASIST TEMP:  ");
      display.print(waterTemp);
      display.setCursor(1, 36);
      display.print("FUEL PRES:   ");
      display.print(oilPressure);
      display.setCursor(1, 54);
      display.print("GEARBOX TEMP:");
      display.print(oilTemp);
    case 3:
      display.setTextSize(1); // Tamaño de texto pequeño
      display.setTextColor(SSD1306_WHITE); // Color del texto
      display.setCursor(0, 0); // Posición en la esquina superior izquierda
      display.print("Pagina 3"); // Texto a mostrar
      display.display();
    case 4:
     display.drawBitmap(0, 0, spoon, SCREEN_WIDTH, SCREEN_HEIGHT, SSD1306_WHITE);
  display.display();
  pinMode(buzzerPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP); // Configurar el pin del botón como entrada con resistencia pull-up
  sensors.begin();
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.display();
  delay(3000);
  int textHeight = 16;
  int scrollSpeed = 2;
  for (int y = SCREEN_HEIGHT; y > -textHeight; y -= scrollSpeed) {
    display.setTextSize(2);
    display.setCursor(20, y);
    display.print("READY TO");
    display.setCursor(20, y + textHeight);
    display.print(" RACE!!");
    display.display();
    delay(10);
  mostrarMenuVertical();
  bool buttonPressed = (digitalRead(buttonPin) == LOW); // Detectar si el botón está presionado
  // Manejo de estado del botón con debounce
  if (buttonPressed && !buttonWasPressed && (currentMillis - lastButtonPress) > debounceDelay) {
    lastButtonPress = currentMillis;
    buttonWasPressed = true;
    if (currentState == MENU_VERTICAL) {
      currentState = PAGINA;
      mostrarPagina(currentPage);
    delay(200); // Delay para evitar rebotes del botón
  // Resetear el estado del botón cuando se suelta
  if (!buttonPressed) {
  // Controlar el cambio de página con el encoder solo si estamos en el menú vertical
    long newPosition = encoder.read();
    int delta = newPosition - lastPosition;
    if (abs(delta) >= encoderThreshold) {
      if (delta > 0) {
        currentPage = (currentPage + 1) % menuSections;
        currentPage = (currentPage - 1 + menuSections) % menuSections;
      lastPosition = newPosition;
      mostrarMenuVertical(); // Actualizar el menú vertical inmediatamente
#define thermoDO1 3
#define thermoCS1 4
#define thermoDO2 6
#define thermoCS2 7
#define thermoDO3 9
float temp5 = 0.0;
enum State {
  MENU_VERTICAL,
  PAGINA
    switch (i) {
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
  display.display();
    case 0:
    case 1:
    case 2:
    case 3:
      display.display();
    case 4:
  display.display();
  sensors.begin();
    for (;;);
  display.display();
  delay(3000);
    display.display();
    delay(10);
      if (delta > 0) {
Please post the full output when you try to upload the second sketch. Turn on verbose reporting in the IDE preferences and use code tags when you post the output to make it easier to read
Which Arduino board are you using ?
I'm using Arduino UNO and the problem that I have is that IDE is not giving me any error when I'm trying to upload and IDE said that it was uploaded successfully, that's why I'm confused
Hi @fojonracing
Please provide a detailed description of what made you think it didn't upload, even though you didn't see any errors.
this is the code that I can not upload
#define thermoDO1 3
#define thermoCS1 4
#define thermoDO2 6
#define thermoCS2 7
#define thermoDO3 9
Encoder encoder(2, 3); // CLK a pin 2, DT a pin 3
// Declaración de termocuplas
// Define la imagen en forma de array de bytes (bitmap)
float temp5 = 0.0;
enum State {
  MENU_VERTICAL,
  PAGINA
    switch (i) {
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
  display.display();
    case 0:
    case 1:
    case 2:
    case 3:
      // Calcular el porcentaje de la suma de ambas presiones
      float totalPressure = pressure1 + pressure2;
      float percentage = (totalPressure / (2 * pressureMax)) * 100.0;
      // Mostrar la información
      display.print("Pressure 1: ");
      display.setCursor(0, 16);
      display.print("Pressure 2: ");
      display.setCursor(0, 32);
      display.print("Total Pressure: ");
      display.print(totalPressure, 2);
      display.setCursor(0, 48);
      display.print("Percentage: ");
      display.print(percentage, 2);
      display.println("%");
    case 4:
  display.display();
  sensors.begin();
    for (;;);
  display.display();
  delay(3000);
    display.display();
    delay(10);
      if (delta > 0) {
because when I upload it the screen its completely black and did not show nothing
I think you have drawn the wrong conclusion. More likely the sketch is uploading, but the runtime behavior of your sketch program is not as you expect.
So you need to carefully evaluate the differences between the sketch that produces the behavior you expect and the sketch that produces the behavior you don't expect. Find the specific difference in the code that causes the "completely black and did not show anything" symptom.
You can methodically reduce the number of changes in the non-working sketch until you have only the specific changes that cause it to have the unexpected behavior. I notice that a lot of the changes between the two were just moving code around to different places in the sketch.
You're more than likely running out of memory. I compiled your code (for an Uno) and get
Sketch uses 24502 bytes (75%) of program storage space. Maximum is 32256 bytes.
Global variables use 923 bytes (45%) of dynamic memory, leaving 1125 bytes for local variables. Maximum is 2048 bytes.
For the Adafruit display library, you will need to add 128x64 = 1kByte to the global variables.
