Sketch uses 984 bytes (3%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\.\COM1": The system cannot find the file specified.
i received this message after i click upload. i am using ATmega 328P PU, windows 7 64bit. what should i do? i can only see my LED from pin 13 blinking.
You need to select the COM port of your Arduino from the Tools > Port menu. If that menu is disabled then you may need to install a driver for the USB-serial chip or maybe you have a bad(or charging only) USB cable.
I successfully Installed driver for my ft232rl USB to UART but when I tried to update it in device manager, it can't find the file needed even though file destination is correct
