Hello Arduino family!
I am using Arduino UNO and trying to uploading a blink sketch. I have used different ports , different cable and also restarting the computer, but issue is irregular error messages. sometimes the arduino compiled, but sometimes it gives different errors. following are some errors
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
the selected serial port avrdude: stk500_recv(): programmer is not responding
does not exist or your board is not connected
option enabled in File -> Preferences.
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x10
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x10
avrdude: stk500_set_extended_parms(): protocol error, expect=0x14, resp=0x10
avrdude: stk500_initialize(): failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
An error occurred while uploading the sketch
avrdude: arduino_read_sig_bytes(): (a) protocol error, expect=0x14, resp=0x1e
avrdude: error reading signature data for part "ATmega328P", rc=-2
avrdude: error reading signature data, rc=-2
avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x10
I'm not getting what is the main reason for this behaviour, kindly help
