I'm trying to upload the sketch below and I'm getting an error. I tried uploading a blink sketch and that works, but not the following code:
ST25DV64KC Example
By: Ricardo Ramos and Paul Clark
SparkFun Electronics
Date: July, 2022
License: MIT. Please see the license file for more information but you can
basically do whatever you want with this code.
This example reads the tag device ID and revision number over I2C and outputs
them to the serial port
Feel like supporting open source hardware?
Buy a board from SparkFun!
SparkFun Qwiic RFID Tag - ST25DV64KC : https://www.sparkfun.com/products/19035
Hardware Connections:
Plug a Qwiic cable into the Qwiic RFID Tag and a RedBoard
If you don't have a platform with a Qwiic connection use the SparkFun Qwiic Breadboard Jumper (https://www.sparkfun.com/products/14425)
Open the serial monitor at 115200 baud to see the output
#include <SparkFun_ST25DV64KC_Arduino_Library.h> // Click here to get the library: http://librarymanager/All#SparkFun_ST25DV64KC
SFE_ST25DV64KC tag;
Wire.begin();
Serial.println(F("ST25DV64KC example."));
if (!tag.begin(Wire))
Serial.println(F("ST25 not detected. Freezing..."));
while (1) // Do nothing more
Serial.println(F("ST25 connected."));
uint8_t values[8] = {0};
if (tag.getDeviceUID(values))
Serial.print(F("Device UID: "));
for (uint8_t i = 0; i < 8; I++)
if (values[i] < 0x0a)
Serial.print(F("0"));
Serial.print(values[i], HEX);
Serial.print(F(" "));
Serial.println(F("Could not read device UID!"));
uint8_t rev;
if (tag.getDeviceRevision(&rev))
Serial.print(F("Revision: "));
Serial.println(rev);
Serial.println(F("Could not read device revision!"));
// Nothing to do here
The upload takes a long time. About halfway through, I get this error:
No upload port found, using /dev/cu.usbmodem11101 as fallback
And eventually, I get this error:
Timeout. The IDE has not received the 'success' message from the monitor after successfully connecting to it. Could not connect to /dev/cu.usbmodem11101 serial port.
I will note that I have a sensor with the following connections:
SCL to SCL
SDA to SDA
Vcc to 3.3v
GND to GND
Any help would be greatly appreciated. Thank you.
