Error uploading to ESP-03 8266
Hello everyone.
I'm trying to uplaod code to my ESP-03, with these settings:
Generic ESP8266 Module,
CPU frequency: 80MHz
Flash Frequency: 40MHZ
Flash Mode: DIO
baud rate: 115200
Flash size: 4M(1M SPIFFS)
Reset Method: ck
Wiring
VCC - 3.3V
GND - GND
CH_PD -
TXD - TX (computer)
RXD - RX (computer)
GPIO2 -
does anyone have advice?
thank you
  • Iacopo
Google for instructions on how to upload a sketch to an esp. Your connections are incorrect.
PaulRB:
Hi. Thanks for that, but I do believe my ESP may be damaged or even broken.. Ive followed the connections and nothing is working
Like PaulRB said, the connections you've tried are wrong.
You can't have two devices transmitting on the same line. Device one should transmit to the receiver line of device two, and device two should transmit to the receive line of device one.
You didn't enable the chip, either. CH_PD shouldn't be floating.
As far as I know, there aren't any 4MB versions of the ESP-03, only 0.5MB. You probably want to use QIO mode instead of DIO.
What reset circuitry are you using? Did you tie GPIO0 to ground manually while resetting/uploading?
Read more on how to connect the ESP8266 here: https://tttapa.github.io/ESP8266/Chap02 - Hardware.html
And how to program it here: https://tttapa.github.io/ESP8266/Chap06 - Uploading.html
Pieter
