i was uploading my program to the arduino board and got the following error message
Arduino: 1.8.6 Hourly Build 2018/07/20 10:33 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 5646 bytes (2%) of program storage space. Maximum is 253952 bytes.
Global variables use 393 bytes (4%) of dynamic memory, leaving 7799 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_setparm(): failed to set parameter 0x9e
avrdude: stk500v2_command(): unknown status 0xc8
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
An error occurred while uploading the sketch
Invalid library found in C:\Users\Lenovo\Documents\Arduino\libraries\Led_Project_ATL_lab: C:\Users\Lenovo\Documents\Arduino\libraries\Led_Project_ATL_lab
option enabled in File -> Preferences.
i dont understand what it is supposed to mean. please help
That means that the sketch compiled, but the IDE can't connect via the serial port. Have you set the correct port in the Tools, Port menu?
i was trying to upload my code to arduino mega and got this error message. please help me.
Sketch uses 4898 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 383 bytes (4%) of dynamic memory, leaving 7809 bytes for local variables. Maximum is 8192 bytes.
this check.
