Error Uploading
Arduino: 1.6.13 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,146 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 14 bytes (0%) of dynamic memory, leaving 2,034 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfa
Problem uploading to board.
Which board are you using ? Which board have you got selected ?
Which port are you using ? Which port have you got selected ?
Have you got anything connected to pins 0 or 1 ?
Have you tried installing the drivers that are distributed with the IDE?
Take a read of the attached document and see what applies to you.
Arduino troubleshooting for beginners.doc (368 KB)
