ERROR UPLOADING
Arduino: 1.8.0 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Hey there,
i am Nandan. I am getting the above error pl. help me out..... as soon as possible
Is the board detected by your Windows system?
Check this:
  1. Unplug the USB cable
  2. Open the device manager
  3. Plug the cable in again
  4. Does device manager show a new device?
    -> if yes, open the new device and check what COM-port was allocated
    This is the COM-port which has to be selected in IDE, together with the right board (Mega) and as programmer use "ArduinoISP"
-> if no, you need to install the right USB/serial communication driver to get your Mega detected
that is not working out.
The rx led starts blinking
what do you mean by "that" ? -> be precise!
ok, and now? What shall we do with that information?
Pls go back to my previous post and tell us exactly what you did and what the results are.
I tried
rpt007:
Check this:
When I try to upload the rx and tx led blinks alternately after 5 seconds.
This were not my questions and instructions.
Did you check with the device manager if your Mega is recognized at all by your PC?
yup, I checked it all.
Fine, and with what results?
the results were:
Nandan_Shukla:
Hey there,
and
Nandan_Shukla:
Nandan_Shukla:
Apparently you did not follow my advice; you just keep repeating the old replies.
I can't help you on thta basis. Sorry, but I am wasting my time here.
