Error uploading
When I try to upload the example servo knob code this error message pops up
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
pls help and note I'm new to this so.... I might be asking a dumb question
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
(deleted)
Sketch uses 2028 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
C:\Users\ISINDU WICKRAMASEKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\ISINDU WICKRAMASEKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\ISINDU~1\AppData\Local\Temp\arduino_build_340218/sketch_mar30a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\ISINDU WICKRAMASEKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
It came upto this and it was still uploading but it won't go any further.
#include <Servo.h>
Servo servo;
  servo.attach(8);
  servo.write(0);
  delay(2000);
void loop(){
  servo.write(90);
  servo.write(0);
  delay(100);
         Using Port                    : COM3
This is the code I used. and the updated error message
If you're using a clone, chances are it uses the CH340 device driver. Do you know if it is installed on your system? If not, search "CH340 download" and download/install the driver. Also, some clones are using an older bootloader (I think the menu sequence is Tools --> Bootloader), so you might trying using the older bootloader. You will need to restart the system for the driver to take effect.
I installed that a while ago
try a differenct USB port.
