error uploding on board Lambda
error messages :
Arduino: 1.8.5 (Windows 8.1), Board: “LAMBDA (Lite/Basic/Plus)”
In file included from C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:35:0:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\config/AltSoftSerial_Boards.h:136:2: error: #error “Please define your board timer and pins”
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In static member function ‘static void AltSoftSerial::init(uint32_t)’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:74:27: error: ‘CONFIG_TIMER_NOPRESCALE’ was not declared in this scope
CONFIG_TIMER_NOPRESCALE();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:79:28: error: ‘CONFIG_TIMER_PRESCALE_8’ was not declared in this scope
CONFIG_TIMER_PRESCALE_8();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:104:10: error: ‘INPUT_CAPTURE_PIN’ was not declared in this scope
pinMode(INPUT_CAPTURE_PIN, INPUT_PULLUP);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:105:15: error: ‘OUTPUT_COMPARE_A_PIN’ was not declared in this scope
digitalWrite(OUTPUT_COMPARE_A_PIN, HIGH);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:113:27: error: ‘ENABLE_INT_INPUT_CAPTURE’ was not declared in this scope
ENABLE_INT_INPUT_CAPTURE();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In static member function ‘static void AltSoftSerial::end()’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:118:24: error: ‘DISABLE_INT_COMPARE_B’ was not declared in this scope
DISABLE_INT_COMPARE_B();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:119:28: error: ‘DISABLE_INT_INPUT_CAPTURE’ was not declared in this scope
DISABLE_INT_INPUT_CAPTURE();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:122:24: error: ‘DISABLE_INT_COMPARE_A’ was not declared in this scope
DISABLE_INT_COMPARE_A();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In static member function ‘static void AltSoftSerial::writeByte(uint8_t)’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:147:24: error: ‘ENABLE_INT_COMPARE_A’ was not declared in this scope
ENABLE_INT_COMPARE_A();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:148:22: error: ‘CONFIG_MATCH_CLEAR’ was not declared in this scope
CONFIG_MATCH_CLEAR();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:149:33: error: ‘GET_TIMER_COUNT’ was not declared in this scope
SET_COMPARE_A(GET_TIMER_COUNT() + 16);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:149:39: error: ‘SET_COMPARE_A’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In function ‘void COMPARE_A_INTERRUPT()’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:162:25: error: ‘GET_COMPARE_A’ was not declared in this scope
target = GET_COMPARE_A();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:173:22: error: ‘CONFIG_MATCH_SET’ was not declared in this scope
CONFIG_MATCH_SET();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:175:24: error: ‘CONFIG_MATCH_CLEAR’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:177:24: error: ‘SET_COMPARE_A’ was not declared in this scope
SET_COMPARE_A(target);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:191:40: error: ‘SET_COMPARE_A’ was not declared in this scope
SET_COMPARE_A(target + ticks_per_bit);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:194:24: error: ‘CONFIG_MATCH_NORMAL’ was not declared in this scope
CONFIG_MATCH_NORMAL();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:195:26: error: ‘DISABLE_INT_COMPARE_A’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:202:22: error: ‘CONFIG_MATCH_CLEAR’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:204:40: error: ‘SET_COMPARE_A’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:206:34: error: ‘GET_TIMER_COUNT’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:206:40: error: ‘SET_COMPARE_A’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In function ‘void CAPTURE_INTERRUPT()’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:228:30: error: ‘GET_INPUT_CAPTURE’ was not declared in this scope
capture = GET_INPUT_CAPTURE();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:231:31: error: ‘CONFIG_CAPTURE_FALLING_EDGE’ was not declared in this scope
CONFIG_CAPTURE_FALLING_EDGE();
Multiple libraries were found for “AltSoftSerial.h”
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:234:30: error: ‘CONFIG_CAPTURE_RISING_EDGE’ was not declared in this scope
Used: C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial
CONFIG_CAPTURE_RISING_EDGE();
Not used: C:\Users\CCS_LP\Documents\Arduino\libraries\AIS_NB_BC95
Not used: C:\Program Files (x86)\Arduino\libraries\AIS_NB_BC95-master
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:241:21: error: ‘SET_COMPARE_B’ was not declared in this scope
SET_COMPARE_B(end);
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:242:25: error: ‘ENABLE_INT_COMPARE_B’ was not declared in this scope
ENABLE_INT_COMPARE_B();
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:256:27: error: ‘DISABLE_INT_COMPARE_B’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:263:33: error: ‘CONFIG_CAPTURE_FALLING_EDGE’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp: In function ‘void COMPARE_B_INTERRUPT()’:
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:279:24: error: ‘DISABLE_INT_COMPARE_B’ was not declared in this scope
C:\Users\CCS_LP\Documents\Arduino\libraries\AltSoftSerial\AltSoftSerial.cpp:280:30: error: ‘CONFIG_CAPTURE_FALLING_EDGE’ was not declared in this scope
exit status 1
Error compiling for board LAMBDA (Lite/Basic/Plus).
“Show verbose output during compilation”
option enabled in File → Preferences.
If someone have idea.
please help me. :slight_smile: :frowning:
simple_send_IoTtweet.ino (1.38 KB)
It looks like your "LAMBDA" board uses the ATmega328PB:
Apparently the AltSoftSerial library is not compatible with that microcontroller.
You will either need to add support for ATmega328PB the library or else not use it.
