Error usando la libreria FastLed
Hola, estoy usando una tira de led a la cual le quiero poner que se apague en una opción, cuando le añado esta línea:
 if ( Efecto == 11)  {
    set_max_power_in_volt_and_milliamps(0,0);
me da este error,
exit status 1
'CambiarEfecto' was not declared in this scope
#include <FastLED.h>
//////////CONFIGURACIÓN///////////
#define LED_PIN     5
#define BUTTON_PIN  3
#define NUM_LEDS    15
#define BRIGHTNESS  200
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
/////////////PARA DESARROLLADORES/////////////
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
int Efecto;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
  delay( 3000 ); // power-up safety delay
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(  BRIGHTNESS );
  currentPalette = RainbowColors_p;
  currentBlending = LINEARBLEND;
  Efecto = 0;
  attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), CambiarEfecto, RISING);
  ChangePalette();
  static uint8_t startIndex = 0;
  startIndex = startIndex + 1; /* motion speed */
  FillLEDsFromPaletteColors( startIndex);
  FastLED.show();
  FastLED.delay(1000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
  uint8_t brightness = 255;
  for ( int i = 0; i < NUM_LEDS; ++i) {
    leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
    colorIndex += 3;
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.  All are shown here.
void ChangePalette()
  if ( Efecto ==  0)  {
  if ( Efecto == 1)  {
    currentPalette = RainbowStripeColors_p;
    currentBlending = NOBLEND;
  if ( Efecto == 2)  {
  if ( Efecto == 3)  {
    SetupPurpleAndGreenPalette();
  if ( Efecto == 4)  {
    currentPalette = ForestColors_p;
  if ( Efecto == 5)  {
    SetupPurpleAndPurpleStripedPalette();
  if ( Efecto == 6)  {
  if ( Efecto == 7)  {
    currentPalette = CloudColors_p;
  if ( Efecto == 8)  {
    currentPalette = PartyColors_p;
  if ( Efecto == 9)  {
    currentPalette = LavaColors_p;
  if ( Efecto == 10)  {
    currentPalette = OceanColors_p;
void CambiarEfecto() {
  if (Efecto >= 11)Efecto = 0;
  else Efecto++;
// This function fills the palette with totally random colors.
void SetupTotallyRandomPalette()
  for ( int i = 0; i < 16; ++i) {
    currentPalette[i] = CHSV( random8(), 255, random8());
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupPurpleAndPurpleStripedPalette()
  // 'black out' all 16 palette entries...
  fill_solid( currentPalette, 16, CRGB::Purple);
  // and set every fourth one to white.
  currentPalette[0] = CRGB::Purple;
  currentPalette[4] = CRGB::White;
  currentPalette[8] = CRGB::White;
  currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
  CRGB purple = CHSV( HUE_PURPLE, 255, 255);
  CRGB green  = CHSV( HUE_GREEN, 255, 255);
  CRGB black  = CRGB::Black;
  currentPalette = CRGBPalette16(
                     green,  green,  black,  black,
                     purple, purple, black,  black,
                     purple, purple, black,  black );
// This example shows how to set up a static color palette
// which is stored in PROGMEM (flash), which is almost always more
// plentiful than RAM.  A static PROGMEM palette like this
// takes up 64 bytes of flash.
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
  CRGB::Red,
  CRGB::Gray, // 'white' is too bright compared to red and blue
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Red,
  CRGB::Red,
  CRGB::Gray,
  CRGB::Gray,
  CRGB::Blue,
  CRGB::Blue,
  CRGB::Black,
  CRGB::Black
Tienes que quitar la llave "}" que está justo antes del if() que has agregado.
Tenias razón, pero me sale otro error
exit status 1
'set_max_power_in_volt_and_milliamps' was not declared in this scope
In function 'void ChangePalette()':
ColorPaletteConBoton:120:5: error: 'set_max_power_in_volt_and_milliamps' was not declared in this scope
uggested alternative: 'set_max_power_in_volts_and_milliamps'
Solucionado la "s" de volt
