error: usbtiny_transmit
Dear friends,
I have an own designed board with a Atmega328 in TQFP32 package which I try to burn a boatloader onto with such a programmer: https://www.sparkfun.com/products/9825
I am using Win10 and the lates USBTiny driver I could find.
verbose output is:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
Error while burning bootloader.
         System wide configuration file is "C:\Users\LocalUser\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: error: usbtiny_transmit:
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
The programmer is hooked up to the atmega without the 5v line, as the atmega is powered externally with 3.3v. The ground of external power and the programmer are connected.
I have one idea, but it is hard to test it for me, so I'd like to ask you whether you think it is worth a try: the MISO, MOSI and SCK lines are also used by another chip on that board, to communicate with the atmega. Could it be that this second chip interferes with the communication between the programmer and the atmega?
Thank you for any hints!
I just flipped the switch on the programmer to power the target (but I did not connect it as I don't want the board to receive 5v)
now the error looks like this:
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9516
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
Looks like you're using a board definition for at ATmega328p, but you assembled your board using an ATmega328pb. These are different parts with extra features and different signature, hence avrdude correctly reports that the signature is wrong.
For atmega328pb, would suggest using MCUDude's MiniCore - note the caveat in documentation about additional step required to work with the pb series parts.
That said, another solution is to tell it that it's talking to a 328pb when burning the bootloader, but use a bootloader that lies about the signature and returns the sig of 328p, and treat it as one. This works, because everything in the 328p is present and works the same way in the 328pb - the pb just has some additional features (which you would not be able to use with this method)
