Hello! I have the following setup:
Arduino Mega 2560 connected to breadboard. LED's hooked up to pins 7-9, capicator on reset-ground on 2560, and the SCK, MOSI, and MISO pins connected to the lilypad, and to their corresponding pins on the mega 2560 as indicated by the sketch for ARDUINO AS ISP. I got this error message:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Using library PalatisSoftPWM in folder: C:\Users\Andrew\Documents\Arduino\libraries\PalatisSoftPWM-master
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\Andrew\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.5\cores\arduino -IC:\Users\Andrew\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.5\variants\mega -IC:\Users\Andrew\Documents\Arduino\libraries\PalatisSoftPWM-master C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\JojoDress_prototype_3.cpp -o C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\JojoDress_prototype_3.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\hooks.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\WInterrupts.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\wiring.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\wiring_analog.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\wiring_digital.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\wiring_pulse.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\wiring_shift.c.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\abi.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\CDC.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\HID.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\IPAddress.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\main.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\new.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\Print.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\Stream.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\Tone.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\USBCore.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\WMath.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\WString.cpp.o
Using previously compiled file: C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\core.a
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -w -Os -Wl,--gc-sections,--relax -mmcu=atmega2560 -o C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.elf C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp\JojoDress_prototype_3.cpp.o C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/core.a -LC:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp -lm
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.elf C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.eep
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy -O ihex -R .eeprom C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.elf C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.hex
Sketch uses 6,488 bytes (2%) of program storage space. Maximum is 253,952 bytes.
Global variables use 358 bytes (4%) of dynamic memory, leaving 7,834 bytes for local variables. Maximum is 8,192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users\Andrew\AppData\Local\Temp\build1472781655208487636.tmp/JojoDress_prototype_3.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Not sure what is causing this error, or what any of that stuff means. Do I have something hooked up wrong, or should I test a component for failure?
