Error using Arduino as MQTT client
I'm using Arduino Mega 2560 and Ethernet shield 2 (W5500) to send MQTT messages to my Home assistant (Raspberry Pi). The Home assistant are running a MQTT broker (Mosquitto). Arduino connects to the MQTT broker and is able to send messages for 30-90 seconds before gives an error. The error is "MQTT_CONNECTION_TIMEOUT" but I can't figure out how to fix this. Anyone have an idea??
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Function prototypes
void subscribeReceive(char* topic, byte* payload, unsigned int length);
// IP and MAC adress
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x4F, 0x77 };
IPAddress ip(192, 168, 1, 214);
// Adress to MQTT server!
const IPAddress server(192, 168, 1, 140);
// Ethernet and MQTT related objects
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
// Constant definitions
const int ledPin = 22;
const int bortePin = 23;
const int utePin = 24;
const int sparetempPin = 25;
const int frostsikringPin = 26;
const int lysitrappPin = 27;
bool borteState = false ; // Initial setting
bool LastborteState = false ; // Initial setting Lastbortestate
bool uteState = false ; // Initial setting uteState
bool LastuteState = false; // Initial setting Lastutestate
bool hjemmeState = true ; // Initial setting hjemmeState
bool LasthjemmeState = true ; // Initial setting LasthjemmeState
bool sparetemp = false ; // Initial setting sparetemp
bool frostsikr = false ; //Initial setting frostsikr
bool LysitrappState = false ; // Initial setting LysitrappState
bool LastLysitrappState = false ; //Initial setting LastLysitrappstate
//Deactivate SD-card on the SPI-bus
pinMode(53, OUTPUT);
digitalWrite(53, HIGH);
pinMode(10, OUTPUT);
//pinMode(4, OUTPUT);
//digitalWrite(4, HIGH);
// Useful for debugging purposes
// Start the ethernet connection
Ethernet.begin(mac, ip);
// Ethernet takes some time to boot!
delay(3000);
// Set the MQTT server to the server stated above ^
mqttClient.setServer(server, 1883);
// Attempt to connect to the server with the ID "Mqttuser"
if (mqttClient.connect("ArduinoMqtt", "Mqttuser", "Mqttuser"))
Serial.println("Connection has been established, well done");
// Establish the subscribe event
// mqttClient.setCallback(subscribeReceive);
Serial.println("Looks like the server connection failed...");
// PinMode definitions
pinMode(ledPin, OUTPUT);
pinMode(bortePin, INPUT_PULLUP);
pinMode(utePin, INPUT_PULLUP);
pinMode(lysitrappPin, INPUT_PULLUP);
// This is needed at the top of the loop!
mqttClient.loop();
// Status connection
if (mqttClient.state()==0)
Serial.println(mqttClient.state());
// Stairlight ON/OFF for coordination with Home assistant
// Read status stairlight from Centrol (inverted PULL_UP):
LysitrappState = !digitalRead(lysitrappPin);
// Compare status stairlight with previous state
if (LysitrappState == LastLysitrappState)
// If status has changed, parameter for LastLysitrappState and sendes MQTT message to Home Assistant
LastLysitrappState = LysitrappState;
// If status has changed to OFF send MQTT message
if (LastLysitrappState == false)
// Writing status to screen, turn checklight off
Serial.println("Lys i trapp AV");
digitalWrite(ledPin,LOW);
// Sendeing message "off" to topic "home/trapp/lights"
if(mqttClient.publish("home/trapp/lights", "off"))
Serial.println("Publish message success");
Serial.println("Could not send message :(");
if (LastLysitrappState == true)
// Writing status on screen, turn checklight on
Serial.println("Lys i trapp PÅ");
digitalWrite(ledPin,HIGH);
// Sendeing message "on" to topic "home/trapp/lights"
if(mqttClient.publish("home/trapp/lights", "on"))
You have no reconnect feature in your code. So if the connection to the server gets reset for any reason your code simply fails. As you have no subscriptions even mosquitto may disconnect your client after some time, any router on the route too. Don't you think there's a reason almost any PubSubClient example has the reconnect feature?
