hello ![]()
I am currently experiencing an error when attempting to verify and upload programming code of the cooking hacks e-health sensor shield with the arduino. My main aim is to upload the program that will display SpO2 on the Serial monitor.
Arduino: 1.5.8 (Windows 7), Board: "Arduino Uno"
In file included from C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:33:0:
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.h:149:15: error: 'prog_uint8_t' has not been declared
PROGMEM prog_uint8_t *array);
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:41:11: error: 'prog_uint8_t' does not name a type
PROGMEM prog_uint8_t eHealthLogo[] = {
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:109:10: error: 'prog_uint8_t' does not name a type
PROGMEM prog_uint8_t cookingLogo[] = {
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp: In member function 'void eHealthDisplayClass::init()':
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:201:21: error: 'eHealthLogo' was not declared in this scope
image(0,64,128,64,eHealthLogo);
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:209:21: error: 'cookingLogo' was not declared in this scope
image(0,64,128,64,cookingLogo); delay(3000);
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp: At global scope:
C:\Users\tapiwa\Documents\Arduino\libraries\eHealth\eHealthDisplay.cpp:663:20: error: 'prog_uint8_t' has not been declared
Error compiling.
here are may codes below one is for PinChangeInt.h and ehealth.h
PinChangeInt.h
PinChangeInt.h
See google code project for latest, bugs and info http://code.google.com/p/arduino-pinchangeint/
For more information Refer to avr-gcc header files, arduino source and atmega datasheet.
This library was inspired by and derived from "johnboiles" (it seems)
PCInt Arduino Playground example here: http://www.arduino.cc/playground/Main/PcInt
If you are the original author, please let us know at the google code page
It provides an extension to the interrupt support for arduino by
adding pin change interrupts, giving a way for users to have
interrupts drive off of any pin.
Please make any configuration changes in the accompanying PinChangeIntConfig.h file.
This will help avoid having to reset your config in the event of changes to the
library code (just don't replace that file when you update).
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Â See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. Â If not, see <http://www.gnu.org/licenses/>.
#ifndef _STDDEF_H
#include "stddef.h"
#endif
#ifndef PinChangeInt_h
#define PinChangeInt_h
#include "PinChangeIntConfig.h"
#ifndef Arduino_h
#include "Arduino.h"
#endif
* Theory: all IO pins on Atmega168 are covered by Pin Change Interrupts.
* The PCINT corresponding to the pin must be enabled and masked, and
* an ISR routine provided. Â Since PCINTs are per port, not per pin, the ISR
* must use some logic to actually implement a per-pin interrupt service.
/* Pin to interrupt map:
* D0-D7 = PCINT 16-23 = PCIR2 = PD = PCIE2 = pcmsk2
* D8-D13 = PCINT 0-5 = PCIR0 = PB = PCIE0 = pcmsk0
* A0-A5 (D14-D19) = PCINT 8-13 = PCIR1 = PC = PCIE1 = pcmsk1
#ifndef MAX_PIN_CHANGE_PINS
#define MAX_PIN_CHANGE_PINS 1
#endif
// You can reduce the memory footprint of this handler by declaring that there will be no pin change interrupts
// on any of the three ports.
// define NO_PORTB_PINCHANGES to indicate that port b will not be used for pin change interrupts
// define NO_PORTC_PINCHANGES to indicate that port c will not be used for pin change interrupts
// define NO_PORTD_PINCHANGES to indicate that port d will not be used for pin change interrupts
// If only a single port remains, the handler will be declared inline reducing the size and latency
// of the handler.
// if their is only one PCInt vector in use the code can be inlined
// reducing latecncy and code size
#define INLINE_PCINT
#if ((defined(NO_PORTB_PINCHANGES) && defined(NO_PORTC_PINCHANGES)) || \
(defined(NO_PORTC_PINCHANGES) && defined(NO_PORTD_PINCHANGES)) || \
(defined(NO_PORTD_PINCHANGES) && defined(NO_PORTB_PINCHANGES)))
#undef INLINE_PCINT
#define INLINE_PCINT inline
#endif
// Provide drop in compatibility with johnboiles PCInt project at
// http://www.arduino.cc/playground/Main/PcInt
#define PCdetachInterrupt(pin) PCintPort::detachInterrupt(pin)
#define PCattachInterrupt(pin,userFunc,mode) PCintPort::attachInterrupt(pin, userFunc,mode)
typedef void (*PCIntvoidFuncPtr)(void);
class PCintPort {
PCintPort(int index,volatile uint8_t& maskReg) :
portInputReg(*portInputRegister(index + 2)),
pcmask(maskReg),
PCICRbit(1 << index),
PCintLast(0) {
for (int i = 0; i < 9; i++) {
pcIntPins[i] = NULL;
public:
static void attachInterrupt(uint8_t pin, PCIntvoidFuncPtr userFunc, int mode);
static void detachInterrupt(uint8_t pin);
INLINE_PCINT void PCint();
static PCintPort pcIntPorts[];
protected:
class PCintPin {
public:
PCintPin() :
PCintFunc((PCIntvoidFuncPtr)NULL),
PCintMode(0) {}
PCIntvoidFuncPtr PCintFunc;
uint8_t PCintMode;
uint8_t PCIntMask;
static PCintPin pinDataAlloc[MAX_PIN_CHANGE_PINS];
void addPin(uint8_t mode,uint8_t mask,PCIntvoidFuncPtr userFunc);
void delPin(uint8_t mask);
volatile uint8_t& portInputReg;
volatile uint8_t& pcmask;
const uint8_t PCICRbit;
uint8_t PCintLast;
PCintPin* pcIntPins[9]; // extra entry is a barrier
#endif
Please kindly help me. Many thanks ![]()
