I’m trying to send readings from an arduino-enabled IMU to a Sparkfun ESP 32 Thing microcontroller using the Wire.h library. I was using the Master Write/Slave Reader example just to see how it works. The Master Writer part for the IMU uploads without problems, but the Slave Reader for the microcontroller gets a compiling error:
"sketch\slaveReceiver.ino.cpp.o:(.literal._Z5setupv+0x18): undefined reference to `TwoWire::onReceive(void (*)(int))’
sketch\slaveReceiver.ino.cpp.o: In function `setup()’:
C:\Users\Taylor\Documents\slaveReceiver/slaveReceiver.ino:22: undefined reference to `TwoWire::onReceive(void (*)(int))’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board SparkFun ESP32 Thing. "
Here’s the code I’m using for the receiving end…
#include <Wire.h>
Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
Any suggestions would be great.
