error:  variable or field declared void
New with Arduino (X-Mas gift) and I’ve been trying to figure out where my syntax is wrong. Getting:
error: variable or field ‘fade’ declared void
Unsure why this won’t compile. Any help appreciated…
#define RED 11
pinMode(RED, OUTPUT);
void fade(color)
  int i = 0;
  for (i = 0; i < 255; i++) {
    analogWrite(color, i);
    delay(10);
  for (i = 255; i > 0; i--) {
    delay(10);
 char x[ ]="RED";
 fade(x);
You will need to indicate the datatype for color. Something like this...
void fade( byte color )
Remove x from setup and call fade using the #define you declared earlier...
 fade( RED );
Finally, welcome to the forum!
Thanks! Now receiving:
error: expected constructor, destructor, or type conversion before ‘(’ token
and it’s highlighting this line:
Modified code:
#define RED 11
void fade(byte color)
  int i = 0;
    delay(10);
    delay(10);
 fade(RED);
Move this...
...to the beginning of setup...
  fade(RED);
Genius! Thanks for the help.
I wish the errors were a little more intuitive.
Final question:
If I add another LED, and do this:
loop()
fade ( RED );
fade ( YEL );
...they fade sequentially. How can I fade them simultaneously?
Thanks!
Would I create an array of LEDs I want to fade, and pass that to the fade() subroutine? And the fade() would have to be re-coded to accept an array?
Genius!
I certainly appreciate the compliment but "Experienced!" is more accurate. ;)
You are welcome. I hope your Christmas present has been fun so far.
The general solution is to use something called a "finite state machine". If you continue working with your new Arduino, it's worth learning about them. This is a fairly good place to start... http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
For this Sketch, I suspect your suggestion...
...will work well and give you an opportunity to learn about arrays and learn more about function parameters.
Some LED fading stuff that may help... http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206438619/0 http://www.arduino.cc/en/Tutorial/ColorCrossfader http://stackoverflow.com/questions/676133/fade-in-multiple-leds-with-arduino http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1226962662/0#0 http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1235225449/13
