Error w/auto format, but compiles fine?
Maybe i should not even care because the program compiles and runs fine as far as i can tell but when i hit auto format i get the following error message.
Binary sketch size: 6776 bytes (of a 14336 byte maximum)
java.lang.ArrayIndexOutOfBoundsException: 10
      at processing.app.tools.AutoFormat.show(AutoFormat.java:561)
      at processing.app.Editor$15.actionPerformed(Editor.java:728)
      at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
      at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
      at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
      at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
      at javax.swing.AbstractButton.doClick(AbstractButton.java:334)
      at javax.swing.AbstractButton.doClick(AbstractButton.java:282)
      at javax.swing.plaf.basic.BasicMenuItemUI$Actions.actionPerformed(BasicMenuItemUI.java:1020)
      at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1576)
      at javax.swing.JComponent.processKeyBinding(JComponent.java:2772)
      at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:656)
      at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:664)
      at javax.swing.JMenuBar.processKeyBinding(JMenuBar.java:640)
      at javax.swing.KeyboardManager.fireBinding(KeyboardManager.java:255)
      at javax.swing.KeyboardManager.fireKeyboardAction(KeyboardManager.java:242)
      at javax.swing.JComponent.processKeyBindingsForAllComponents(JComponent.java:2849)
      at javax.swing.JComponent.processKeyBindings(JComponent.java:2841)
      at javax.swing.JComponent.processKeyEvent(JComponent.java:2735)
      at java.awt.Component.processEvent(Component.java:5360)
      at java.awt.Container.processEvent(Container.java:2010)
      at java.awt.Component.dispatchEventImpl(Component.java:4050)
      at java.awt.Container.dispatchEventImpl(Container.java:2068)
      at java.awt.Component.dispatchEvent(Component.java:3885)
      at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1826)
      at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:681)
      at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:938)
      at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:810)
      at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:645)
      at java.awt.Component.dispatchEventImpl(Component.java:3923)
      at java.awt.Window.dispatchEventImpl(Window.java:1791)
      at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
      at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
      at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
      at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
This started popping up after i added 3 else statements in addition to the original 5.
any ideas.... should i even be concerned?
Probably not, but you might want to post your code. If you can find a small sketch that has the same problem, that's even better.
Do you have commented out curly braces: {}? Or curly braces in a string?
