This may be a very simple problem, but I am just a starter of Arduino. Could anyone give me a hint please...
When I want to compile this following code, the following error appears
mbs_system.h:34:error:"MAX17043" does not name a type
base_station:55:error: "time_t" does not name a type
the code is as following
#include <SPI.h>
#include <WiFi.h>
#include <SD.h>
#include <Wire.h>
#include <Time.h>
#include <Cosm.h>
#include <HttpClient.h>
#include <SoftwareSerial.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
#include <BGLib.h>
#include <MAX17043.h>
#include "pitches.h"
#include "mbs_defs.h"
#include "mbs_stringtable.h"
#include "mbs_wifi.h"
#include "mbs_sd.h"
#include "mbs_ble.h"
#include "mbs_piezo.h"
#include "mbs_system.h"
#include "mbs_menu.h"
/*************************** Global Variables ***************************/
char compiledate[] = __DATE__;
char compiletime[] = __TIME__;
/*Wifi Shield*/
//TODO: replace with parameters read from SD card
char ssid[] = "DanHowePhone"; // your network SSID (name)
char pass[] = "sMt52dSp"; // your network password
//char ssid[] = "CaseGuest"; // your network SSID (name)
//char pass[] = "sMt52dSp"; // your network password
//float baseVolts;
//float baseSOC;
//float devVolt[6];
float devSOC[12];
long loopTime; //
long loopProcessStart; // used for testing loop processing time
extern time_t systemTime;
extern char months[12][4];
extern int status;
uint8 loopSecs;
/* LCD Shield */
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
//mbsLcdMenu lcdMenu = mbsLcdMenu(); //need instantiation of virtual class?
mbsTopMenu topMenu = mbsTopMenu();
SETUP
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
//Initialize LCD
lcd.begin(16, 2);
lcd.setBacklight(LCD_BL_WHITE);
//Display splash screen on LCD and banner on terminal
displaySeparator('#',30);
DisplayStringSerial(MBS_STR_MSS_BASESTATION,true);
Serial.print(compiledate);
Serial.print(" ");
Serial.println(compiletime);
DisplayStringLCD(MBS_STR_MSS_BASESTATION,0,0);
lcd.setCursor(0,1);
lcd.print(compiledate);
lcd.setCursor(7,1);
lcd.print(" "); //remove year
lcd.setCursor(8,1);
lcd.print(compiletime);
//mbsPiezoStartTone(); //Start-up tone
delay(1500); //make sure screen has time to display
lcd.setBacklight(LCD_BL_TEAL);
//Initialize hardware
MbsSdInit(); //Initialize SD card
MbsWifiInit(); //Initialize WiFi connection
//mbsCreateTimestamp();//testing!
MbsBleInit(); //Initialize BLE shield
//Check to see if fuel gauge is present
//mbsFuelGaugeQuickStart();
//mbsCheckFuelGauge();
loopTime = millis();
Serial.println("Initialization complete");
//Display date and time on LCD
//Update time displayed on LCD
mbsLcdShowDate();
lcd.setCursor(8,0);
if(hour()<10) lcd.print("0");
lcd.print(hour());
lcd.print(":");
if(minute()<10) lcd.print("0");
lcd.print(minute());
lcd.print(":");
if(second()<10)lcd.print("0");
lcd.print(second());
lcd.setBacklight(0);
}//End setup()
uint8_t cnt= 0x80;
* Loop *
if(second() != loopSecs) {
loopSecs = second(); //only execute once per second
if(second() == 0 ){//1 minute tasks
if(minute() == 3){ //hourly tasks (staggered from startup)
if(hour() == 0){ //daily tasks
lcd.clear();
mbsLcdShowDate();
//MbsGetTimeWifi(); // update time 1 time per day
}//hour == 0
}//minute == 0
//if(minute() % 5 == 1){ //check devices every 5 minutes
if(1){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Listening for");
lcd.setCursor(0,1);
lcd.print("MSS3 devices");
mbsBleDeviceScan(10);
lcd.clear();
mbsLcdShowDate();
lcd.setBacklight(0); //turn off
if(minute() % 10 == 0){ //upload data every 10 minutes
status = WiFi.begin(ssid);//Turn on WiFi and upload
if( strcmp(ssid,WiFi.SSID()) == 0){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Uploading data");
lcd.setCursor(0,1);
lcd.print("to Cosm server");
sendCosmBaseData();//Sending data to cosm
lcd.clear();
mbsLcdShowDate();
lcd.setBacklight(0); //turn off BL
for(uint8_t i=0;i<12;i++) devSOC[i]=0; //clear values
WiFi.disconnect();//Turn off WiFi
}//minute % 10 = 0
} //second == 0 (1 minute tasks)
//1s tasks
lcd.setCursor(8,0);
lcd.print(hour());
lcd.print(":");
lcd.print(":");
}//loopSecs
}//End loop()
