so I'm new to arduino and I'm using some examples.
the basics no problem, move onto something more difficult and i get the same error every time. basically.
my code is the sweep example for servo motors.
note i get the same error with ir, motors and the knob example. basically everything other then blink.........
am i missing something?
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
the errors are
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp: In member function 'uint8_t SoftwareServo::attach(int)':
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:27: error: 'digitalWrite' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:28: error: 'OUTPUT' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:28: error: 'pinMode' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp: In member function 'void SoftwareServo::write(int)':
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:51: error: 'clockCyclesPerMicrosecond' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp: In static member function 'static void SoftwareServo::refresh()':
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:73: error: 'millis' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:106: error: 'digitalWrite' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:108: error: 'TCNT0' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/SoftwareServo/SoftwareServo.cpp:123: error: 'digitalWrite' was not declared in this scope
It looks like you have a third-party library called "SoftwareServo" installed. That seems to be interfering with the use of the built-in Servo library. Perhaps you should remove that library and re-start the IDE to clear the conflict.
// Sweep
#include <Servo.h>
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In function 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:81: error: 'LOW' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:81: error: 'digitalWrite' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:88: error: 'HIGH' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:88: error: 'digitalWrite' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:92: error: 'clockCyclesPerMicrosecond' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: At global scope:
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:232: error: 'boolean' does not name a type
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In constructor 'Servo::Servo()':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:249: error: 'clockCyclesPerMicrosecond' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'uint8_t Servo::attach(int, int, int)':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:263: error: 'OUTPUT' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:263: error: 'pinMode' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:270: error: 'isTimerActive' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'void Servo::detach()':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:281: error: 'isTimerActive' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'void Servo::write(int)':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:292: error: 'map' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'void Servo::writeMicroseconds(int)':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:300: error: 'byte' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:300: error: expected `;' before 'channel'
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:301: error: 'channel' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:309: error: 'clockCyclesPerMicrosecond' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'int Servo::read()':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:320: error: 'map' was not declared in this scope
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp: In member function 'int Servo::readMicroseconds()':
/Users/arcturus/Documents/Arduino/libraries/Servo/Servo.cpp:327: error: 'clockCyclesPerMicrosecond' was not declared in this scope
