Error when checking airtime balance using AT commands
The serial monitor displays OK after the AT command for checking airtime balance and begins displaying "+C" and gets stuck just there.It does not continue to display the airtime balance.I am using an arduino Uno.
//Include Library because we are using digital pins for connection
#include <SoftwareSerial.h>
#include "SIM900.h"
/Initializing digital pins for connection to serve as Rx and Tx
Rx pin is 7 and Tx pin is 8
SoftwareSerial SIM900(7, 8 );
//Variable for storing incoming messsages content
char incoming_char=0;
//Variable to store airtime balance string
char airtime;
// initialize digital pin 13 as an output
pinMode(13, OUTPUT);
// Baudrate for serial monitor
Serial.begin(19200);
//Baudrate for GSM shield
SIM900.begin(19200);
// Give time to log on to network.
delay(20000);
// Turn the LED on (HIGH is the voltage level)
digitalWrite(13, HIGH);
delay(100);
// Set SMS mode to text for GSM MODULE
SIM900.print("AT+CMGF=1\r");
delay(100);
SIM900.print("AT+CNMI=2,2,0,0,0\r");
// blurt out contents of new SMS upon receipt to the GSM shield's serial out
delay(100);
//Change Character Set to GSM
//SIM900.print("AT+CSCS="GSM"\r");
//AT command to check airtime balance
SIM900.println("AT+CUSD=1,"*124#"\r");
delay(100);
//Send Message function intialization
// SendMessage();
// Now we simply display any text that the GSM shield sends out on the serial monitor
if(SIM900.available() >0)
//Get the character from the cellular serial port.
incoming_char=SIM900.read();
//Print the incoming character to the terminal.
Serial.print(incoming_char);
//Function to SMS based on airtime status
void SendMessage(){
//Storing credit balance details in airtime variable
airtime = SIM900.print("AT+CUSD=1,"*124#"\r");
//Conditional Statement for credit balance
if (airtime < 1.00){
//Turn the LED on (LOW is the voltage level)
digitalWrite(13, LOW);
//Sets the GSM Module in text mode
//Delay of 100 milli seconds
delay(100);
//Phone number to send SMS
SIM900.print("AT+CMGS="+233246692584"\r");
delay(100);
//The SMS text you want to send
SIM900.print("Your a/c is Below GHC1.00,You have been DISCONNECTED !! ");
delay(100);
//ASCII code of CTRL+Z
SIM900.print((char)26);
delay(100);
else {
delay(100);
delay(100);
SIM900.print("Your a/c is Above GHC1.00,You are CONNECTED !! ");
delay(100);
delay(100);
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool. I recommend you to use the standard IDE instead.
What is SIM900.h? When your code requires a library that's not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
What is the purpose of the 1000 ms delay here:
  if (SIM900.available() > 0)
    incoming_char = SIM900.read();
  airtime = SIM900.print("AT+CUSD=1,\"*124#\"\r");
Please take some time to read and understand https://www.arduino.cc/en/Reference/SoftwareSerialPrint, especially the "Returns" section.
The delay is there so that when all incoming messages are displayed,it waits for 1000 milliseconds before proceeding
I included #include "SIM900.h" because I was told to add that library because I was using a SIM900 GSM modem
Kelvinkwame:
But that will delay 1000 ms between printing each character of the incoming message, seems very slow.
Kelvinkwame:
I just don't see anywhere in the code where that is used but I would need to look at the file to know for sure. Please post a link to where you downloaded the file from. Use the chain links icon on the toolbar to make the URL clickable.
pert:
