Error when compiling my 4x4x4 cube code
Hi all.
I have been sneaking around on the site for a year now and have been working with smaller arduino circuit doing that time.
I have just started my first "bigger" DIY projekt. A 4x4x4 LedCube.
I will run the cube with 2 Shift register for the positive site of the 16 leds in each layer, and 4 NPN transistors for the ground site of the Leds.
I have started making my code with just some of the leds on for test.
When I was trying to compile the code I got the following error:
_4x4x4:43: error: integer constant is too large for 'long' type
If I make the following change it will compile without error.
The line:
layer[3] = 0000111100001111, BIN;
is changed to
layer[3] = 000011110001111, BIN;
I dont get any errors on the other layer int. why?
Thanks in advance :wink:
Here is my code.
// 4x4x4 LedCube Ver. 0.1
// Connection for the first Shift Register
int latchPin = 11;
int dataPin = 12;
int clockPin = 13;
// Layerpin is the 4 digital output where the 4 transistors are connected.
// On = that layer is connected to ground
int layerPin[4] = {6, 7, 8, 9};
// Int for storing the binary data for each layer - 1 frame
unsigned int layer[4];
// Int that holds the data that's going to be shifted out
int dataOut;
//delays
int layerDelay = 10;
int frameDelay = 100;
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  digitalWrite(latchPin, LOW);
  digitalWrite(dataPin, LOW);
  digitalWrite(clockPin, LOW);
  dataOut = 0000000000000000, BIN;
  shiftOut(dataOut);
  digitalWrite(latchPin, HIGH);
  // Hardcode the animation
  layer[0] = 0000000100000001, BIN;
  layer[1] = 0000001100000011, BIN;
  layer[2] = 0000011100000111, BIN;
  // Send all layers to shiftOut()
  for (int i=0; i<=3; i++)
    shiftOut(layer[i]);
    digitalWrite(layerPin[i], LOW);
    digitalWrite(layerPin[i], HIGH);
    delay(layerDelay); // Small delay between each layer
  delay(frameDelay); // Delay between each frame
void shiftOut(int data)
  // Shift out 16 bit LSBF on rising egde
  // If you want MSBF change the code to 1>>i instead if 1<<i
  boolean pinState;
  // Set data and clock pin low and ready for shifting
  // For each bit in "data" send out a bit
  for (int i=0; i<=15; i++)
   //set clockPin to LOW prior to sending bit
   // if the value of DataOut and (logical AND) a bitmask
   // are true, set pinState to 1 (HIGH)
    if ( dataOut & (1<<i) )
      pinState = HIGH;
      pinState = LOW;
    //sets dataPin to HIGH or LOW depending on pinState
  digitalWrite(dataPin, pinState);
  //send bit out on rising edge of clock
  digitalWrite(clockPin, HIGH);
//stop shifting out data
Additional information:
Arduino Uno with IDE 0022 on a MacBook Pro OSX Lion
One more note:
If you guys have other comments on my code, please let me know.
Im a big noob in this exciting world of Arduino :wink:
/ Shhh
You don't define a binary constant like that.
Even if you could it only works for 8 bit values according to this:-
Okay.
So instead of
I have to do this?
layer[3] = (B00001111 * 256) + B00001111
/Shhh
Yes, but why use binary hex is much simpler
is just
layer[3] = 0x0F0F
Or you could use an unsigned int binary constant:
layer[3] = 0b0000111100001111u;
I have never fully understand the HEX system, but maybe now the time is come? :wink:
I think I Will try the unsigned int binary solution first, and when my code is up running, The plan is to code a Python program to make som more advance controlling (Sound controlled etc) here I might try to work with the HEX system!
Thanks for The reply
/shhh
