Error when compliling. PLS can i get some help
#include “Servo.h”
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#include <Adafruit_Fingerprint.h>
#define LCD_ROWS 2
#define LCD_COLUMNS 16
#define SCROLL_DELAY 150
#define BACKLIGHT 255
#define SERVO9G_PIN_SIG 8
#define SS_PIN 10
#define RST_PIN 9
LiquidCrystal_I2C lcd(0x27, 16, 2);
MFRC522 rfid;
const int servo9gRestPosition = 0; //Starting position
const int servo9gTargetPosition = 180; //Position when event is detected
int getFingerprintIDez();
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Servo servo9g;
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
rfid.PCD_Init(); // Initiate MFRC522
Serial.println(“Approximate your card to the reader…”);
lcd.begin(16, 2); lcd.setCursor(0, 0); lcd.print(“SCAN YOUR FINGER”);
lcd.begin(16, 2); lcd.setCursor(0, 1); lcd.print(" SCAN YOUR CARD ");
//initialize RFID module
servo9g.attach(SERVO9G_PIN_SIG);
servo9g.write(servo9gRestPosition);
delay(100);
servo9g.detach();
lcd.init(); // initialize the lcd
lcd.backlight();
// Look for new cards
if ( !rfid.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! rfid.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print(“UID tag :”);
String content = “”;
byte letter;
for (byte i = 0; i < rfid.uid.size; i++)
Serial.print(rfid.uid.uidByte < 0x10 ? " 0" : " ");
_ Serial.print(rfid.uid.uidByte*, HEX);_
_ content.concat(String(rfid.uid.uidByte < 0x10 ? " 0" : " "));
content.concat(String(rfid.uid.uidByte, HEX));
Serial.print("Message : “);
content.toUpperCase();
if (content.substring(1) == “3A 91 88 AB,08 24 BE E8”); //change here the UID of the card/cards that you want to give access*
* Serial.println(“Authorized access”);
lcd.clear(); // Clear LCD screen.
lcd.print(” WELCOME “); // Print print String to LCD on first line*
* lcd.setCursor(0, 1); // Set cursor at the begining of line 2*
* lcd.print(” BOSS “);_
_ servo9g.write(servo9gTargetPosition);
delay(10000);
; // Print print String to LCD on second line*
* delay(10000);
{ if (getFingerprintIDez() >= 0)
* lcd.print(” BOSS ");_
delay(10000);
* delay(10000);
}*_
Can we get some code tags and some error messages, please?
READ the top of this forum!! CLICK HERE
Well - what does the error message say?
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\User\AppData\Local\Temp\cclqlgZL.ltrans1.ltrans.o: In function `loop':
C:\Users\User\Desktop\fingerprint_test/fingerprint_test.ino:67: undefined reference to `getFingerprintIDez()'
C:\Users\User\Desktop\fingerprint_test/fingerprint_test.ino:113: undefined reference to `getFingerprintIDez()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
No, I can't see it either.
are you sure you are using the right fingerprint library?
How did you install the library?
Try using the Arduino search function to get the library.
OP:
Are you going to talk to us at all? Or are you just going to thumb your nose at our forum rules and improperly post code and error messages and say nothing about them and then expect us to fix it for you? How about showing a little respect for the people offering you FREE help. At least take the time to read the forum rules and post things properly.
