I wrote a Arduino sketch for version 0023. It's works well. Now I update too version 1.0.2. Change the extension of the sketch from xx.pde too xx.ino
But when I compile I get errors.
Who can help me?
Jack
Below the sketch:
//Weerstation
#include <SHT1x.h>
#include <Wire.h>
#include <BMP085.h>
BMP085 bmp;
// Specify data and clock connections and instantiate SHT1x object
#define dataPin 4
#define clockPin 5
SHT1x sht1x(dataPin, clockPin);
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 20 chars and 4 line display
bmp.begin();
lcd.init(); // initialize the lcd
lcd.begin(20,4);
lcd.clear();
lcd.backlight();
float temp_c;
float humidity;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
humidity = sht1x.readHumidity();
// Print the values to the serial LCD
lcd.setCursor(0,0); //1ste rij LCD
lcd.print("T1 "); //Temperatuur binnen
lcd.print(temp_c, 1);
lcd.print((char)223); //Graden symbool
lcd.print("C");
lcd.setCursor(11,0); //1ste rij LCD
lcd.print("RV1 "); //Luchtvochtigheid binnen
lcd.print(humidity, 1);
lcd.print("%");
lcd.setCursor(0,2); //3de rij LCD
lcd.print("LD "); //Luchtdruk
lcd.print((bmp.readPressure()/100)+1);
lcd.print("mBar");
delay(5000);
Moderator edit: </mark> <mark>[code]</mark> <mark>
In file included from Weerstation.ino:5:
R:\Mijn Documenten\Arduino\libraries\Weerstation/SHT1x.h:15:22: error: WProgram.h: No such file or directory
In file included from Weerstation.ino:4:
R:\Mijn Documenten\Arduino\libraries\Weerstation/LiquidCrystal_I2C.h:81: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
R:\Mijn Documenten\Program Files\Arduino\arduino-1.0.2\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
jack100:
I haven't read the sticky topic.
I don't have experience with programming.
Therefore I have only change the extension of the sketch from .pde to .ino
Well if you are not willing to read the sticky which tells you what to do then why should I repeat that information.
The fact that you don't have any programming experience does not prevent you from reading does it?
You have to change a file in the libary and the sticky tells you what.
Only this 2 errors continue:
R:\Mijn Documenten\Arduino\libraries\Weerstation\LiquidCrystal_I2C.cpp:219: error: prototype for 'void LiquidCrystal_I2C::write(uint8_t)' does not match any in class 'LiquidCrystal_I2C'
R:\Mijn Documenten\Arduino\libraries\Weerstation/LiquidCrystal_I2C.h:81: error: candidate is: virtual size_t LiquidCrystal_I2C::write(uint8_t)
That one is covered, too. The LiquidCrystal_I2C hasn't been updated for 1.0+ use. Edit the header file for the library, and change the return type of the write() method from void to size_t. Edit the source file and make the same change. At the end of the write() method add a return statement to return a value, usually 1.
